dynojet vs. dyno dynamics good info...
Old Jun 16, 2008 | 09:19 AM
Rotor Nut.
i figured this deserved its own thread since alot of people think that dynojets dont show "real" hp numbers. well i have been hunting down some info on dyno dynamics. most of the time when the dyno is used properly they will read 14-16% lower then a dynojet. here is a very good thread i found on freshalloy that shows a 240 dynoing a very high number on a dyno dynamics. what is said to have happened was the the bar. pressure was setup incorrectly. my point is that dynojet is the most consistant dyno for comparison. ie. posting online and comparing with one car setup to another. not to take anything away from a dyno dynamics they are better to tune because of the controlable load.
here is the link.
http://forums.freshalloy.com/showthr...t=gt3076r+dyno
Old Jun 16, 2008 | 10:03 AM
FCNAred's Avatar
if you want to make comparisons using a dyno dynamics then you should be in "shoot out mode." i've never really understood the fascination with numbers as long as the car is tuned well, i'd rather chase other cars than chase numbers. to each his own though.
Old Jun 16, 2008 | 11:07 AM
ZAN_TUNING's Avatar
Just turn up the boost!
exactly, shootout mode is for numbers.
Th0m4s
Feb 26, 2019 02:04 AM
eddierotary
Aug 16, 2015 04:12 PM
Turblown
Aug 14, 2015 04:48 PM
Clacor
Aug 14, 2015 09:17 AM
