what makes you think it's fuel cut? Unless there is a problem with the Rtek (not likely), you are not hitting boost-induced fuel cut. The Rtek 1.7 essentially deleted the code in the stock ECU for fuel cut. You have another problem, such as a clogged cat, sever ignition breakup, or serious detonation.
-- 1988 Rx-7 Turbo II, T04R
-- 1997 Infiniti Q45 Touring
-- Sold: 1988 Rx-7 GTU, 172rwhp all motor
-- RIP: 1989 Supra
