Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Plug N Play EMS?
Old Jun 1, 2008 | 05:58 PM
T24U's Avatar
Plug N Play EMS?
Is there any EMS that I can plug directly into the factory harness connections? An adapter maybe?
Old Jun 2, 2008 | 10:22 PM
Evil Aviator's Avatar
Rotorhead
The Wolf EMS computers can plug into the stock wiring harness (mostly), and Microtech EMS computers can use the stock sensors. AEM used to have a plug and play EMS for Mazdas, but I have not seen them advertise it lately so they may have dropped it from their line. Anyway, while it is nice to have this capability, I don't really like it myself because the stock wiring is old and unreliable, the stock sensors are expensive, and the tuning is the difficult/expensive part anyway. It is a lot easier to troubleshoot an EMS with a good wiring harness and new sensors vs. one hooked up to crusty old wiring and half-dead sensors.
If you are trying to save time and/or money, I think it is just better to pay a professional to install and tune the EMS. While it may seem like you could save money otherwise, when you add up the extra time it would take you, as well the fact that you have a much better chance of ruining your expensive engine and very little chance of tuning it properly, you are better off just working overtime at your regular job (or a side job) and paying somebody who knows what they are doing. You can spend your time making something less critical (CAI, interior parts, gauges, etc.) if you just like tinkering.
Old Jun 2, 2008 | 11:11 PM
T24U's Avatar
Well, I believe my harness is ok, but it is nice to have that piece of mind.
I rebuilt my motor, so I think that I can handle installing an EMS. Like you said this is an issue of time/money.
A friend of mine installed a Microtech, and it took him a while to figure it out, but seems to be working nicely now.
I know that I can sell my ECU, MAF, pressure sensor, harness, etc etc and recover some of the money spent on the EMS.
I will probably end up buying a used EMS and Wideband o2/controller. Just thought that there might be an easier way.
What's the details on the Rtek coming out for S5 TII? Is this basically a modified ECU, or is it a whole different setup.
One reason why I want to do this is because I have a full emmissions delete, and every time the car starts to boost the check engine light comes on and it goes into limp mode. Runs good and strong until I decel or am at a light then it bogs down, and backfires (like it's overfueling), until I restart. If I drive easy it usually stays off, for about 15 minutes anyways. If I go into boost it comes on immediately.
Getting codes for OMP, O2, solenoids, and a coil code. I assume most of it is because of the emissions delete, the factory ECU is just wiggin out on me. I know that a standalone can fix these issues.
Old Jun 23, 2008 | 10:54 AM
lkky00245's Avatar
Exclamation maplestoryer.com
People are mystified about how to cook ribs properly. I'm going to walk you through every step using a basic charcoal grill.maplestoryer sell maple story mesos Obviously if you have different or more high-tech equipment, you'll need to modify these procedures. If you're setting up your backyard charcoal grill for indirect cooking, you'll want to use a disposable aluminum pan to capture the grease maple story power leveling as the fat renders while cooking. Some people add water to this pan to add moisture to the cooking environment.
Old Jul 6, 2008 | 10:45 PM
Siverturbo's Avatar
Platinum Certified tuner
You can try the Haltech E8 with the S5 patch harness , installation should take you 5 minutes.
_Tones_
May 25, 2021 05:37 AM
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
