Old 05-25-08, 02:17 PM   #1
7fold
7fold's Avatar
Rtek 7, i want one soooo bad!
so, for all of you with one, what controller are you using and what do you like and not like about them, im going to be getting the Rtek 2.0 and i would like to see what controlers most people have had success with...
pics of your setup would be cool too
87 n/a- CS 2.5 inch header, CS 80mm pre-silencer
CS 80mm cat-back, Custom cold air (for real) intake
lowered 1.5 inches, Emissions Removed
ICW wheels, MSD 6a ignition
E-fan, AC removed.
7fold is offline   Reply With Quote
Old 05-26-08, 07:59 PM   #2
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
dontn get a T3, or any other that uses teh same connector. my old m100 worked perfect and was cheap ($30 on ebay a couple years back) but had no backlit display
gxl90rx7 is offline   Reply With Quote
Old 05-27-08, 03:10 AM   #3
boost_its_what_for_dinner
RotoriousRx7
boost_its_what_for_dinner's Avatar
i have a sony clie` and it works great but i think the cable has a loose conection and it looses connection. but great screen display.
no clue to what they cost since i bought mine from the icecreamman that was on this forum back in march of last year
87 T2 : RR rebuild/SP/JHB jugs : gt35r .82 t4 : 720/1600 : 3"full exhaust : Walboro 255 : big Fmic : KOYO rad./16"e-fan : Greddy Profec b : Apex i bov : uego wb02 : E6X : premix
boost_its_what_for_dinner is offline   Reply With Quote
Old 05-28-08, 12:26 PM   #4
7fold
7fold's Avatar
anyone else????
E-fan, AC removed.
Old 05-28-08, 05:05 PM   #5
HHTurboVert
HHTurboVert's Avatar
CA
I originally used a Sony Clie S320, which worked fine until it I started getting NVRAM check sum errors after which the palm froze and the touch screen has never worked again. Now I use a Sony Clie S300(older model) that I bought for $25 shipped off ebay. It works great, but I wouldn't recommend using it if you have XP because you will have to download driver updates to make it work. Also the connector style on both these models is pretty weak.
The pluses are that they can be had cheap, they are common, the backlight display is nice and the battery life seems to be pretty good.
1988 RX-7 convertible Turbo
Mods:Strt Prt,9.4:1 rotors,FE e-shft & stat grs,BNR Stg 4,Rtek 2.1,4x720cc,FMIC w/spryr,3"exhst/Intke,elc bst cntrl,FD fp ,N20 astd spool,12lb Flywhl,DCF Clutch,RB PP, turbo trans and LSD,120amp alt,ES bshgs weighs 2800
HHTurboVert is offline   Reply With Quote
Old 05-29-08, 01:19 AM   #6
boostedfc3s
1.3 liter piston eater
boostedfc3s's Avatar
I use a Palm E2. It's a little more expensive because it's not a real old model, but I love it. The cable is a nice tight connection, and the display is awesome.
1987 Turbo II. Atkins stage 2 street port w/3mm seals. 60-1 turbo,FMIC,dual pumps,720cc/1680cc,Power FC with Banzai harness. Steve Kan tuned @ 17 psi 352RWHP/296 torque.
boostedfc3s is offline   Reply With Quote
Old 05-31-08, 04:17 PM   #7
WingsofWar
The Firestarter
WingsofWar's Avatar
Send a message via AIM to WingsofWar
Using Palm m515
88 Z31 Turbo - SOLD
98 S14 Turbo - Wrecked
87 TII - SOLD
-EMPTY LOTS and 0 Money Pits MAKE ME SO HAPPY-
WingsofWar is offline   Reply With Quote
What Im I boosting soooo MUCH?? BoostedFd3s 3rd Generation Specific (1993-2002) 10 10-26-06 04:20 PM
Soooo i took my FD to the track...... rosrex7 Time Slips and Dyno 10 06-04-06 12:14 AM
My T2 is soooo light now! boostmotorsport 2nd Generation Specific (1986-1992) 51 02-23-04 04:24 PM
Thank you soooo much....... Law® 2nd Generation Specific (1986-1992) 3 02-10-03 04:55 PM
