Noises, noises...
Old Apr 30, 2002 | 06:32 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Red face Noises, noises...
OK! Ever since i got my 7 ('85), about 3 years ago, i've had an bitch-of-an-annoying-rattle from the front shield that's directly under the fan and pulleys... That shield can move up and down and hit what i think is the oil pan's side protrution (where the upper and lower half meet). I still can't figure out how that shield was originally held in place--maybe a weld broke? invisible screws fell off? how can i make that shield stay still so that whenever i go over bumps it won't rattle!? I absolutely HATE that rattling noise--so whenever i give a friend a ride, i turn up the bass and get the woofer kicking =P
Anyway, someone give me some wisdom and tell me how to secure that shield! If you need pics, I'll get them tomorrow...
Thanx!
P.S. I've been gone from this board for a LONG time and boy do i feel good to be back =)
Old May 5, 2002 | 08:39 PM
FuLLsMoKe's Avatar
Surely you guys have an idea or two?
Old May 5, 2002 | 08:44 PM
RotorMotorDriver's Avatar
Seven Is Coming
Take it off .
~T.J.
Old May 5, 2002 | 08:47 PM
FuLLsMoKe's Avatar
mmmm... besides that? =P
Old May 5, 2002 | 08:51 PM
Felix Wankel's Avatar
Super Newbie
Originally posted by RotorMotorDriver
Take it off .
~T.J.
And watch the temp gauge rise.
The underpan is only secured to the front air dam thing. It just slides in the rear. Maybe you can pull it off and bend the tabs so it fits better.
Old May 5, 2002 | 08:59 PM
FuLLsMoKe's Avatar
Oooo... It'll make the temperature gauge rise?! This is a must do! =P (j/k)
I was thinking of putting a large bolt through it and use it like a clamp, and clamp it to the oil pan's lip--good, bad idea?
Old May 5, 2002 | 09:02 PM
Super Newbie
I was thinking of putting a large bolt through it and use it like a clamp, and clamp it to the oil pan's lip--good, bad idea? The temp should'nt be too high to cause damage, right?
It only moves a little. I had to take mine off because of my aftermarket air dam.
Old May 5, 2002 | 09:05 PM
FuLLsMoKe's Avatar
drats... you spoiled my night...
Old May 6, 2002 | 01:38 AM
SuperPhly's Avatar
****, the interior of my car is FRICKEN loud as it is... did you replace your window/door trim? the stuff that makes a seal with the body? because i have ALL kinds of noises...
especially one from the backend when i hit bumps...
Old May 6, 2002 | 06:05 PM
FuLLsMoKe's Avatar
lol, it's not that bad... the only real noise that's loud enuf to be annoying is the metal shield in the front
other than that, i know that a heat shield is rubbing agains my RB exhaust setup... but that's quiter =P
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
