Anyone ever mount their TURBO behind your head ?
Old May 22, 2008 | 12:25 PM
Viking War Hammer's Avatar
*** Bless The USA
My knucklehead buddy did
Old May 22, 2008 | 12:45 PM
Sarusanj's Avatar
QM
Veteran: Navy
Veteran: Reserves
Interesting. Is there any particular reason?
Old May 22, 2008 | 12:52 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Dude thats awesome!
Yet somehow I'm not feeling it. Wastegate discharge into the cabin? Yea no thanks lol
Old May 22, 2008 | 12:53 PM
setzep's Avatar
It's just too damn cold in the car.
Old May 22, 2008 | 12:54 PM
*** Bless The USA
He's retarded.
Old May 22, 2008 | 12:55 PM
Stanello's Avatar
backslash beanbagrace
That is some funky *** wastegate placement.
Old May 22, 2008 | 02:02 PM
Sarusanj's Avatar
QM
Veteran: Navy
Veteran: Reserves
The bracing to the roll cage is convenient. I guess it goes with the fuel cell in the back seat though.
Old May 22, 2008 | 02:10 PM
crispeed's Avatar
'Tuna'
I guess he never seen a turbine wheel exit the housing!
Old May 22, 2008 | 02:20 PM
*** Bless The USA
it's actually a water tank....... not that it makes it much better
Old May 22, 2008 | 02:24 PM
Nick_d_TII's Avatar
Or quiet.
What about the summer? and Why isn't it under the hood? Wow, better not have any exhaust leaks... Ha Ha...
Gud luck wit dat...
Old May 22, 2008 | 02:59 PM
Juiceh's Avatar
Saiga-12 Power!
Old May 22, 2008 | 03:54 PM
FCNAred's Avatar
dude, what is with the man ******* in the avatar? just wondering...
Old May 22, 2008 | 04:19 PM
BASTARD's Avatar
thats genius ... why didn't I think of that
Old May 22, 2008 | 04:27 PM
RotaryBred's Avatar
Lost You in the Rear View
+1 to that i was thinkin the same thing... seems dangerous as hell to me. hope he has a scatter shield between him and the turbo
Old May 22, 2008 | 06:34 PM
dhahlen's Avatar
FD Under Construction =P
I would like a picture of his head on fire from the extreme heat the turbo produces.... picture of his helmet fused to his head would be nice too
Old Jun 11, 2008 | 01:11 AM
dragFD's Avatar
i understand the concept of doing it...as have been on the same idea for a while now.it kind of works like the N/A theroys of exhaust laws...
tourque gains can be made from putting the turbo in this location.to my understanding it is also backpressure type thing and gains will be more in a high overlap engine(ported engine).the long length runners use the pulses to pull the next exhaust from the rotorhousing.like a tuned length header on a N/A piston motor.it improves low down tourque.basically you can all laugh at it if you like,it isnt necessary to do it like this but will make more power/tourque at a given boost level.basically by putting a turbo on a car you have power anyway..need more? then turn up the boost!...what about without turning up the boost?...longer runners tuned length exhaust headers,along with a different intake manifold/runner design to complement the whole system.ive seen it done on a 13b and have seen the dyno results.it works a treat!.as far as lag is concerned everybody says the same thing when ever they look at a set up like this.in drag racing its not really a problem as 10,000rpm launches would mean you are spinning the turbos hard before you go.having excessive boost low down as letting out the clutch would only fry the tyres on the launch.most of the pros in racing are using "gear dependant" boost controll and step the boost down a bit in the lower gears.as putting any more in would only turn the tyres...so say what ever you like about it but i dont see a problem with the theory of placing the turbo that far away from the motor i think its a good idea....
the only thing i dont like is what a lot of you said about it being dangerous.
it should have been mounted low and covered with steel plate to form a protective firewall.or underneath car..
my 2 cents worth for today...
Old Jun 11, 2008 | 04:24 PM
Newbie
That was the first thing that entered my mind "where's the massive scattershield!" ...
It also looks like the one header pipe will basically be resting on the drivers seat? he can delete his heater core now! .
Old Jun 11, 2008 | 04:51 PM
arghx's Avatar
rotorhead
has nobody ever seen this twin turbo Maxima? guy who went to my college did it... the vehicle recently went to the crusher actually
Old Jun 11, 2008 | 07:01 PM
justturbo2's Avatar
Registered User
^ that $hit is crazy
how did it run?
Old Jun 12, 2008 | 10:36 PM
LSXTASY's Avatar
Ban
Shotgun
Old Jun 12, 2008 | 11:02 PM
Juiceh's Avatar
Saiga-12 Power!
What happened?
Old Jun 12, 2008 | 11:28 PM
neukin's Avatar
not sure what to say... but a little farther and you could have just kept it all in the trunk. Your going to need to buy stock in ear plug companies... Well at least put the bov exit towards your crotch lol
Old Jun 13, 2008 | 07:43 AM
arghx's Avatar
rotorhead
Originally Posted by Juiceh
What happened?
gave up on the project. car ran but not particularly well as you might guess
Old Jun 14, 2008 | 02:50 PM
dragFD's Avatar
yeah mike murillos mustang had the turbos inside the boot.he has had great sucsess with the whole thing despite many peoples beleifs about lag and his auto trans....
check this out....
http://www.mustangblog.com/wp-conten...07/10/1353.jpg
Old Jun 16, 2008 | 06:52 AM
neukin's Avatar
boost can be the best or worst thing in the world.. up to you to make it either or
Nice, that link is pretty sick. The trunk is where the magic happens if your turbo is larger then you.
Well good luck anyways bro. Im sure it will be fun either way just be safe.. think about everything bad and make sure you do something to prevent that bad thing from happening lol
check this out....
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
