I believe that you would be able to run a bridge na or turbo with the rtek 2.1. Like 90gxlrx7 pointed out, the idle timing for the rtek is fixed. However, a bridge will not be idling at the stock rpm or 750. If your bridge port motor idled at 1000+ I think the rtek would be able to run it just fine.
1988 RX-7 convertible Turbo
Mods:Strt Prt,9.4:1 rotors,FE e-shft & stat grs,BNR Stg 4,Rtek 2.1,4x720cc,FMIC w/spryr,3"exhst/Intke,elc bst cntrl,FD fp ,N20 astd spool,12lb Flywhl,DCF Clutch,RB PP, turbo trans and LSD,120amp alt,ES bshgs weighs 2800
