single with stock ecu and intercooler??
Old May 6, 2008 | 10:56 PM
janrx7's Avatar
dominican boost junkie
somebody is selling me the following kit
the kit will include everything new :
- Turbonetics T62-1 t4 Turbo w/polish front housing
- HKS indestructible cast iron racing manifold (1/2 inch thick flanges)
- HKS 50mm race style wastegate
- Greddy style pulley set with belt
- Greddy type RS style blow off valve
- 100K mile 4" high flow air filter "blue, red or silver"
- 3" inch all mandrel bend downpipe with dumptube routed back in to
- Downpipe includes a 2000 degree ceramic coat
- 2.5" inch u-bend intercooler intake pipe w/greddy flange
- All flanges,fitting and clamps
- both oil feed and return oil lines are hi temp "stainless steel"t
and tells me that it will run with with stock ecu and intercooler @14 psi. making 395hp at the flywheel. i am skeptical to say the least. is this setup posible???
Old May 6, 2008 | 11:02 PM
RX7WEEE's Avatar
Need a 20b FD.
If you run the stock ECU with that set up it will blow. Very quickly. You need a fuel system, and a standalone at least.... Read up and use the search....
Old May 6, 2008 | 11:07 PM
Busted7's Avatar
Will work for horsepower
Ebay: i saw that also and i have the same turbo. If you do put that stuff on there i would not go above 9/10 psi. You need alot more to run that setup before you boost 14 psi. This guy is full of crap to make that statment with out warning of the need components to go 14 psi safely. PS 9/10 psi might be too much!
Old May 7, 2008 | 08:18 AM
arghx's Avatar
rotorhead
Those sound like good parts, he is just BSing you about the stock ECU so you'll be more likely to buy it. Get it and go with a Power FC and 1600 secondary injectors.
