Running alternator in FC without stock wiring harness
We have an FC race car that was converted to carb and subsequently had the wiring harness taken out of it, and rewired as simplistic as possible, with no dash/warning lights.
It doesn't seem our alternator is charging though. We have the charge wire hooked to it, but there is another plug on the back that according to the wiring diagram one post gets 12v from ignition, and the other goes through the warning light relay and then to ignition, but we don't have this relay.
Does anyone know why the alternator may not be working? We tried hooking up the 12v ignition portion of that plug to the ignition toggle, but no dice. Does the other plug need a straight 12v or does it need a relay/diode in there?
mmm, then I'm not sure, we solved it with 12V to the plug, but I did notice the S5 alternator didn't charge with 12V at the plug, but the S4 one does. Didn't bother trying to figure out why. If you do find out let me know.
just pick up a one wire alternator. all you have to do is run you alternator wire, which you already have, and your done. or you can have the voltage regulator changed in your factory one and have it converted to a one wire set up. if you go to any auto electric shop they should be able to do that for ya.
Trending Topics
no problem. i had the same dilemma when i installed my microtech and i just switched to a modified gm 100 amp one wire alternator. works just fine but you gotta grind on the mounting brackets to make it work
We put the power to the top wire, it didn't seem to work. We put it to both, and the ignition switch no longer cut power to the ignition box. lol Had to shut off the fuel and hit the master kill.
I noticed this is VERY old but I wanted to chime in for future reference.
I'm re wiring the car because it is also a carb'd FC and I want to utilize the stock switch and turn signal system for when I have to drive it to the event (since its still road legal)
my old harness has been hacked apart and just ugly for years but I run an FD alternator on my S4 chassis, I have just run a fuseable link from the S terminal to terminal B with my molested harness.
I dont use the L terminal at all.
Haven't finished the rewire but we shall see how the S to B+ works out soon enough.
I had issues with non-stock harness charging and fellow racers blowing alternators.
I purchased a GM small body 100a single wire alternator and a dual belt pulley and never looked back.
Very easy to install in the stock location with no space issues. In fact, you can install a full size alternator in stock location w/o issue.
The problem with installing these alternators in this fashion is they don't like backfeed which is what the idiot light relay is there to help do. It feeds a constant resistance with no backfeed voltage.
If you put a bosch relay on the "L" terminal, it will help with charging with little risk of regulator failure.
Its been a long time but i think I had mine hooked up like this:
85 - L Terminal
86 - Ground
87 - Idiot Light +ve (ground other lead)
30 - Hot on ign
This way, it uses the coil of the relay as a constant resistance to "excite" the rectumfinders.
85 - L Terminal
86 - Ground
30 - Hot on ign
How long are your races? A carbed car can run for a while without an alternator. I used a stock idler pulley from the AC belt adjuster and got rid of 11lbs on top of the engine. I run a bigger than stock battery in the area behind where the pass seat woul be.
lol! my brother had a 63 mercedes, and it would run for a week without the alternator (well generator)
but its still plated and I drive it on the streets from time to time.
I use the alternator for these bad boys:
for the night events...
or frozen lakes
its like a scale model of a stage car, may become a stage rally car in 5-10 years (realistically)
We ran some Cibie flame throwers on the front of a Datsun 210 for a 24hr race at Nelsons Ledges back in about '93. One of the guys had stuff laying around from his rally days. We had drivers come up to us and say they liked to follow us into corners because they could actually see where they were going and then they hated to pass us. Sucked for them, it was probably the slowest car on the track (ITC)
I have noticed with L terminal open I have been having voltage regulator issues, (read prematurely fail) thank god I got one with a 3 year warranty. This is mostly my theory right now but it does want to see a resistance for a charge light or voltmeter, so I just wired that terminal to an LED light I got from autozone. It is my everything is okay light, if the light is on - everything is not okay.
RCCAZ 1
Aug 11, 2015 07:05 PM
Thanks!
