Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Boost control and Launch Control??
Old May 2, 2008 | 06:39 AM
raddavey's Avatar
Has anyone been able to setup launch and a sort of 2 stage boost control?
I can only see the launch control working by having an external map and then with a clutch switch switching over to this map which has a lower ignition cut rev limit on it.
Is there another easier (cheaper?) way?
Also boost control. I want less boost in first gear. I was just thinking the easiest way would be to setup the TPS boost trim table and anything under 90% throttle put in -50% boost, so in first gear i'll just not completely open the throttle up and i should be able to launch with less wheelspin. Or i could use the external switch trim, but that means more wiring etc
Any ideas?
Old May 11, 2008 | 08:39 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Ive thought about wiring the extrenal trims into the clutch switch, to pull alot of timming and add alot of fuel to possibly allow a flatshift, howevever ive never tried it.
Old May 12, 2008 | 06:19 PM
Michael Smith's Avatar
Auto's flat shift every time I have a BAD Jatco with lots of goodies inside and it works great. Boost modulated shift ....semi automatic box by Keas in Australia .
Cheers
Michael Smith
