Old 04-25-08, 09:18 AM   #1
Cpt.Zanzibar
Rotary Rocket
Cpt.Zanzibar's Avatar
the Rtek7 S4 NA Stage 2 ECU
http://www.pocketlogger.com/index.ph...age=2&ecu=S4NA
anybody have this done? i have been looking into getting one but im not sure. what are your guys experiences? worht the cashola?
1987 N/A
It goes round and round, not up and down....
Cpt.Zanzibar is offline   Reply With Quote
Old 04-25-08, 09:51 AM   #2
AbortRetryFail
Trunks are for corpses.
AbortRetryFail's Avatar
Send a message via ICQ to AbortRetryFail
I've got one. It's sweet.
I've managed to get a bit more pull in the midrange by tweaking the fuel maps. Nothing extensive until i get a wideband.
The install is a breeze, just plug it in and it's done. It makes setting the idle speed and mixture easier too. (It's done thru software, there's a little 3 page wizard for it.)
The guys over at DigitalTuning are pretty responsive with support too.
Word of wisdom: Don't use a Palm TX - the serial ports on them SUCK and they have all kinds of connection issues.
Just pick up a cheap palm m1xx or m5xx off ebay or something.
AbortRetryFail is offline   Reply With Quote
Old 04-28-08, 08:34 AM   #3
Cpt.Zanzibar
Rotary Rocket
thanks for the info.
one question, how did you install it yourself? the site dosnt give an option to buy the chip itself.
1987 N/A
Old 04-28-08, 10:03 AM   #4
*TOUCH*
Project P --- Pedospeed
*TOUCH*'s Avatar
Trader Score: (12)
i think he meant setting it up, not installing it. i could be wrong but i think you have to send your ecu to them and they send it back with a chip in it. you just plug your ecu back up and go from there setting and tweaking as you like.
*TOUCH* is offline   Reply With Quote
Old 04-28-08, 01:46 PM   #5
Digi7ech
I break Diff mounts
Digi7ech's Avatar
Send a message via AIM to Digi7ech
The stage 2 is not just a flashed chip. It's a daughter board and actual software.
88 GTU w/3mm atkins 13bt TII conversion// Now track car //206rwhp @10.4psi //14.2 @10.4 psi in 1/4 mile
Project Daily drifter// Scrapped and parted
87 TII build
89 240sx Hatch : New daily beater
Digi7ech is offline   Reply With Quote
Old 05-10-08, 04:26 AM   #6
7fold
7fold's Avatar
what kind of interface do you use with the chip? like what do you use to control everything?
87 n/a- CS 2.5 inch header, CS 80mm pre-silencer
CS 80mm cat-back, Custom cold air (for real) intake
lowered 1.5 inches, Emissions Removed
ICW wheels, MSD 6a ignition
E-fan, AC removed.
7fold is offline   Reply With Quote
Old 05-10-08, 11:02 AM   #7
*TOUCH*
*TOUCH*'s Avatar
Trader Score: (12)
palm pilot
Old 05-10-08, 01:27 PM   #8
95nracer
Actual size
95nracer's Avatar
I remember a thread where someone tweaked the fuel maps and was able to gain alot up top.
Edit: Nevermind, its the sticky up top. It was an S5. http://www.rx7club.com/showthread.ph...&highlight=top
12.1@114
95nracer is offline   Reply With Quote
Old 05-12-08, 06:06 AM   #9
fcforlife
rotary tech
fcforlife's Avatar
Trader Score: (9)
Send a message via AIM to fcforlife
can u run a laptop or do you need a palm pilot? what os can u run? whats the turn around time on sending out the ecu?
need parts hit me up 916-880-8281
I'll have another one soon--in the mean time--putting a turbo ka24e in my d21-teehehe
fcforlife is offline   Reply With Quote
Old 05-12-08, 06:11 AM   #10
fcforlife
rotary tech
fcforlife's Avatar
Trader Score: (9)
never mind i read the faq haha
Rtek7 S5 NA Stage 1.0 - MOP Removal - Now available turbo2ltr 2nd Generation Specific (1986-1992) 0 09-17-06 11:36 PM
Rtek7 stage 1 chip RX7FROMCAL 2nd Generation Specific (1986-1992) 3 03-03-06 12:22 PM
SAFC, Rtek7, and stage 2 turbo ERAUMAZDA 2nd Generation Specific (1986-1992) 53 05-19-04 07:49 PM
