S5 TII Dyno results
Old Apr 16, 2008 | 11:08 PM
Ryu's Avatar
Ryu
1991 Frankin7 ***RIP***
S5 TII Dyno results
A couple months back I had my car tuned and was fairly happy with the results. It did 225rwhp on 10psi. Mods are as follows:
~3" Turboback
~Custom TID with Cone filter
~Microtech LT10S
~Walbro 255lph HighFlow pump
~Stock motor with 107,xxxkms on it
~Stock turbo
~Stock injectors
Considering its just intake and exhaust done with a good tune I'd say those are decent numbers. I'm now running 14psi on the same setup and hoping for 250rwhp.
Old Apr 17, 2008 | 03:53 PM
MaczPayne's Avatar
Mac Attack
Not bad, I made pretty much the same RWHP you did on the EXACT setup. The only difference was I had an LT8-s. I made 228whp/210tq @ 10psi.
What kind of boost controller are you using? What were the torque numbers?
In my experience, increasing the boost past 10psi didn't give any significant gains. Instead, I played with my EBC and improved spool-up and boost consistency.
Old Apr 17, 2008 | 07:01 PM
Ryu's Avatar
Ryu
At the time I didn't have a boost controller. Just reaching 10psi from freeing up the intake and exhaust. Now I have an AEM TruBoost and I need to get retuned because my boost is now hitting full about 1000rpms sooner then before.
I haven't got any torque numbers because at the time of the tune the hardware to read and display torque wasn't equiped. Since then the Dyno has been upgraded to show everything it should have before. So once I get back on there and retuned I'll have HP, TQ, and ARF's to share.
Old Apr 18, 2008 | 12:38 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
does the boost drop off near redline? I made about 250whp on same basic mods, the only difference being bigger injectors and a fmic.. boost dropped to 6-7 psi near redline. I would say fmic should be your next mod
Old Apr 18, 2008 | 07:13 PM
Ryu's Avatar
Ryu
Yeah boost peaks and by redline its dropped down to about 7-8psi. The stock turbo's backside is just too small to keep anything more then that all the way to redline.
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
