Old 04-15-08, 12:50 AM   #1
tIIsleeper
pp
tIIsleeper's Avatar
Send a message via AIM to tIIsleeper
false boost readings from my 2.0
when a make a full throttle run my rtek says i get up to 15.8 psi at 3000 rpms. and maxs out at that and stops when i let off. which i know is not true. it seems to read correctly under light throttle and low boost. is the problem my map sensor?
the rtek did detect an error code with the map sensor but i regrounded it and the code disappeared. im assuming when a map sensor goes it defaults to its highest boost reading so the engine doesnt get destroyed which i believe is the case.
i did the voltage check on it and it was a little off. just wondering if anyone had a similar issue.
1987 tII: Custom TID, Greddy FMIC, 255 lph Walbro FP, 720 secondaries, type-s bov, act street/strip clutch, turbo-back RB exhaust, tokico struts, intrax springs, rtek 2.1, lc-1 wideband, 17x8 motoform 5 spokes and s5 tails
tIIsleeper is offline   Reply With Quote
Old 04-24-08, 12:40 AM   #2
HHTurboVert
HHTurboVert's Avatar
The failsafe reading for the boost sensor is 15.8 so if your seeing that you probably do have a problem related to your boost sensor.
1988 RX-7 convertible Turbo
Mods:Strt Prt,9.4:1 rotors,FE e-shft & stat grs,BNR Stg 4,Rtek 2.1,4x720cc,FMIC w/spryr,3"exhst/Intke,elc bst cntrl,FD fp ,N20 astd spool,12lb Flywhl,DCF Clutch,RB PP, turbo trans and LSD,120amp alt,ES bshgs weighs 2800
HHTurboVert is offline   Reply With Quote
Old 04-24-08, 01:05 AM   #3
Henrik
What value do you know to be true?
87TII: K&N, downpipe, S5 turbo, KYB AGX, RTek7 2.0 ECU
90GXL: KYB AGX, RB springs, PR sleeves, RTek7 2.0
Henrik is offline   Reply With Quote
Boost readings synracing33 3rd Generation Specific (1993-2002) 1 10-07-07 11:17 PM
true or false boost question 12leavu 3rd Generation Specific (1993-2002) 10 08-09-07 05:01 PM
Boost Readings Spyder7892 3rd Generation Specific (1993-2002) 11 02-03-07 10:47 AM
boost readings? lovemyseven 3rd Generation Specific (1993-2002) 7 12-11-01 03:24 AM
boost gauge vs PFC boost readings suganuma Power FC Forum 0 09-27-01 10:15 PM
