Microtech I need temp gauge help and air temp sensor clip...questions
Old Apr 10, 2008 | 09:10 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
Could i splice into my water temp sensor thats hooked up to my microtech to my autometer temp gauge
and it doesnt matter what color wire goes to in the sensor
also i need a air temp sensor clip what kinds of car would carry the male end of the clip, i am going junkyard shopping this weekend, i already have the sensor i just need the clip
What does the little 3 leds on the unit mean thers red yellow and green?
Old Apr 11, 2008 | 08:51 PM
rx72c's Avatar
Top Answer: 1
I havnt found any cars that have the air temp sensor plug.
Green means the computer is on.
Orange will flash when the car is on, and with the car off but in reds, if its on means your tps is calibrated etc.
Red means their is an error.
You can splice into the water temp sensor, youd splice into the purple wire. BUT
most likely the autometer guage will have a different range compared to factory sensor.
Best way to do it is to plumb the auto meter electrical sensor.
Old Apr 11, 2008 | 09:31 PM
MODERATOR
cool i went to turn it on today and it was stuttering all over it wouldnt even rev
i took out my plus and the first two where wet i am buying new ones tomorrow to see if i can fix this problem, the car start right off the bat but it idles horribly and stutters when i rev it
Old Apr 11, 2008 | 10:47 PM
rx72c's Avatar
Top Answer: 1
It probably needs a good tune.
IF you should me some data logs while its running like ****.
Then i can help you.
Old Apr 11, 2008 | 10:48 PM
rx72c's Avatar
Top Answer: 1
Also post up your map and i can make some changes to it.
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
LMBTG
Aug 15, 2015 01:43 PM
