NOLOGY wires?
Old Apr 26, 2002 | 12:43 PM
Ryde _Or_Die's Avatar
NOLOGY wires?
I've seen these NOLOGY brand spark plug wires offered a few places now and they cost alot of money($150-250) so I was wondering if they are high-quality. Just never heard of anyone using them. Thanks.
Old Apr 26, 2002 | 01:03 PM
Mark S's Avatar
If they're the capacitive discharge wires, don't get them. They reduce the actual energy transfer though the wire, as decrease spark duration.
I think I remember Ted saying they actually reduced horsepower vs conventional wires.
Old Apr 26, 2002 | 01:11 PM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
They're crap. Run, run like the wind! I had them on my Scirocco and they caused all kinds of problems. Lots of interference, messing with the FI computer, etc.
From Magnacore's website:
"The most notable of exaggerated claims for ignition wires are made by Nology, a recent manufacturer of ignition wires promoted as "the only spark plug wires with built-in capacitor." Nology's "HotWires" (called "Plasma Leads" in the UK) consist of unsuppressed solid metal or spiral conductor ignition wires over which braided metal sleeves are partially fitted. The braided metal sleeves are grounded via straps formed from part of the braiding. Insulating covers are fitted over the braided metal sleeves. These wires are well constructed. For whatever reason, Nology specifies that non-resistor spark plugs need to be used with their "HotWires." In a demonstration, the use of resistor plugs nullifies the visual effect of the brighter spark.
Ignition wires with grounded braided metal sleeves over the cable have come and gone all over the world for (at least) the last 30 years, and similar wires were used over 20 years ago by a few car makers to solve cross-firing problems on early fuel injected engines and RFI problems on fiberglass bodied cars — only to find other problems were created. The recent Circle Track Magazine (USA, May, 1996 issue) test showed Nology "HotWires" produced no additional horsepower (the test actually showed a 10 horsepower decrease when compared to stock carbon conductor wires).
The perceived effect a brighter spark, conducted by an ignition wire, encased or partially encased in a braided metal sleeve (shield) grounded to the engine, jumping across a huge free-air gap (which bears no relationship to the spark needed to fire the variable air/fuel mixture under pressure in a combustion chamber) is continually being re-discovered and cleverly demonstrated by marketers who convince themselves there's monetary value in such a bright spark, and all sorts of wild, completely un-provable claims are made for this phenomena.
Like many in the past, Nology cleverly demonstrates a brighter free-air spark containing useless flash-over created by the crude "capacitor" (effect) of this style of wire. In reality, the bright spark has no more useful energy to fire a variable compressed air/fuel mixture than the clean spark you would see in a similar demonstration using any good carbon conductor wire. What is happening in such a demonstration is the coil output is being unnecessarily boosted to additionally supply spark energy that is induced (and wasted) into the grounded braided metal sleeve around the ignition wire's jacket. To test the validity of this statement, ask the demonstrator to disconnect the ground strap and observe just how much energy is sparking to ground.
Claims by Nology of their "HotWires" creating sparks that are "300 times more powerful," reaching temperatures of "100,000 to 150,000 degrees F" (more than enough to melt spark plug electrodes), spark durations of "4 billionths of a second" (spark duration is controlled by the ignition system itself) and currents of "1,000 amperes" magically evolving in "capacitors" allegedly "built-in" to the ignition wires are as ridiculous as the data and the depiction of sparks in photographs used in advertising material and the price asked for these wires! Most stock ignition primaries are regulated to 6 amperes and the most powerful race ignition to no more than 40 amperes at 12,000 RPM.
It is common knowledge amongst automotive electrical engineers that it is unwise to use ignition wires fitted with grounded braided metal sleeves fitted over ignition cable jackets on an automobile engine. This type of ignition wires forces its cable jackets to become an unsuitable dielectric for a crude capacitor (effect) between the conductor and the braided metal sleeves. While the wires function normally when first fitted, the cable jackets soon break down as a dielectric, and progressively more spark energy is induced from the conductors (though the cable jackets) into the grounded metal sleeves, causing the ignition coil to unnecessarily output more energy to fire both the spark plug gaps and the additional energy lost via the braided metal sleeves. Often this situation leads to ignition coil and control unit overload failures. It should be noted that it is dangerous to use these wires if not grounded to the engine, as the grounding straps will be alive with thousands of volts wanting to ground-out to anything (or body) nearby.
Unless you are prepared to accept poorly suppressed ignition wires that fail sooner than any other type of ignition wires and stretch your ignition system to the limit, and have an engine with no electronic management system and/or exhaust emission controls, it's best not to be influenced by the exaggerated claims, and some vested-interest journalists', resellers' and installers' perception an engine has more power after Nology wires are fitted. Often, after replacing deteriorated wires, any new ignition wires make an engine run better."
I've used them and pulled them. I know someone who used to work at Streetwize and they pulled them all the time.
I recommend:
http://www.racingbeat.com/resultset....rtNumber=11519
That's what I have. Racing Beat knows what's up.
KS
1989 GTUs "Crapology."
Old Apr 26, 2002 | 04:50 PM
RETed's Avatar
My personal experience...
I watched a mildly modded FD run those wires, swap over some NGKs, and then swap the Nologys back on - there was a 5hp lose of power with the Nologys on the DynoJet 248C.&nbsp You make your own conclusions...
-Ted
Old Apr 26, 2002 | 05:06 PM
cymfc3s's Avatar
I Raise Chickens
Ted and Rarest are spot on. Just because its aftermarket, doesnt make it good. Youd be surprized how much an expensive set of garbage aftermarket wires can cause problems.
Old May 24, 2002 | 04:32 AM
ZombeGTA's Avatar
I'm gonna f***ing cry!
Old May 24, 2002 | 06:32 AM
1FastT2's Avatar
I'd definately recommend Magnacore 8.8mm wires. Seem to work great for me.
Old May 24, 2002 | 08:25 AM
yeah i am one of those suckas that ordered the nology wires ill sell you a set with less than 500 miles i have them on my car and cry for spending the money i did on them.my dad put the MSD wires on his car and it has a noticable difference when mine i have felt no difference after reading this i now realize i have probably lost power.
Old May 24, 2002 | 11:30 AM
UniqueTII's Avatar
Slow and old
I second that, but I have the 10mm (yeah, mostly for looks ). Magnecor has pretty much the best prices around, too.
Old May 24, 2002 | 09:33 PM
Pinfield357's Avatar
im using jacobs 8.5mm racing wires i got a noticable change from the NGKs that where on there b4 i changed them. the car now runs much smoother.
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
