removal of A/C????
Old Apr 26, 2002 | 12:02 AM
the_real_bill's Avatar
in your face space coyote
removal of A/C????
Just curious but, if i remove the A/C from my 84GSL, will it create much less drag on the engine???
If so what else has to be removed, besides the A/C pump??? ( i never removed the A/C from a car before)
If it is slowing down my car and burning more gas, i don't want it on there anyway.
It needs to be recharged, and, i'm not going to waste the money on it when i can just roll down the windows and take off the sunroof.
~Vince~
Old Apr 26, 2002 | 12:30 AM
riffraff's Avatar
smog nazi destroyer
if you donot use it, then definatly get rid of it.. just rip out all of the hoses, compressor, canister and what not...
you would also want to remove the a/c coils in front of the radiator as you will no longer need them. with out the a/c they are just unneccesary weight that interupts the airflow to the radiator.
Old Apr 26, 2002 | 11:32 AM
Thanks riffraff,
The next warm day here, i'm gonna rip it all off.
Is there anything else i gotta rip out (on the A/C system)
or is that it. Any electrical?
~Vince~
Old Apr 26, 2002 | 11:34 AM
Oh yeah, will i notice an improvement in gas milage, power, or anything else???
Old Apr 26, 2002 | 12:02 PM
jeremy's Avatar
male stripper
with out it on it just free wheels on the pulley. but it is quite a bit of weight to drop, especially the cast iron bracket that it bolts to and as riffraff said, the condensor inturrupts air flow to the radiator. the only thing else you'll nee dto do that i have yet to do is plug the 2 hardlines going through the firewall if you leave that section under the dash.
Old Apr 26, 2002 | 12:10 PM
thanks for your help guys!
it's defanatly comin off soon.
i'll probably get to it in a week or two.
(packing this weekend, movin to Calgary next weekend)
Old Apr 26, 2002 | 12:16 PM
87turbo2's Avatar
bill..... if your also wanting to free up some power while your at it, how 'bout an electric fan, less parasitic drag plus more room to get to stuff.
Old Apr 26, 2002 | 12:20 PM
I was thinking that, 87turbo2
But i'm not sure how to go about installing an electric fan
i can get one from work REALLY cheap
have you done this to your 7???
Old Apr 26, 2002 | 09:23 PM
ASEmaster's Avatar
What EXACTLY can you use to plug the two hard lines in the firewall?
Old Apr 26, 2002 | 09:35 PM
In case you are wondering my air conditioning system weighed 25.3 lbs. If you are concernded about weight then take out the spare, it weighs 26 lbs.
My two cents
Old Apr 26, 2002 | 10:25 PM
87turbo2's Avatar
I've put it on several of my 7's ( have had 8 ) it's not really all that noticeable powerwise, but it really opens it up under the hood..I've never dynoed it....my TII has no air pump, no p/s pump, and no a/c...just one belt ...too bad it's going bye bye
nimrodTT's Avatar
all aboard!
....better yet rip out the carpet and the sound deadening material, it weighs 65 pounds. I can't remember if that included the spare or not....either way it's a lot of weight.
Old Apr 26, 2002 | 10:55 PM
why did you remove the air pump???
