Putting my new engine together
Old Apr 25, 2002 | 06:17 PM
Jedon's Avatar
Slave2TheFD
I'll put new pictures up every day until the car is running:
http://www.nopro.com/~jedon/engine/
Old Apr 25, 2002 | 06:33 PM
Mr. Stock's Avatar
1993 RX7 R1
Who put the engine together?
Ed
Old Apr 25, 2002 | 06:44 PM
Jedon's Avatar
Slave2TheFD
Larry Scott of Ind. Honda Mazda Care in Escondido.
He builds a lot of 12a bridgeported rally race engines.
-Jedon
Old Apr 25, 2002 | 06:46 PM
Single7's Avatar
Hi Jedon,
When I quickly glanced at your day 1 pics, I was like "oh crap he forgot to put his e-shaft in " - guess I've been working too much lately. Is that a new driver side motor mount? -- to shiny to be used . Are those fiske rims you have in the background? Laters - Tommy
Old Apr 25, 2002 | 06:51 PM
Jedon's Avatar
Slave2TheFD
Hehe that is the old e-shaft, engine has mostly new parts in it
Yes the motor mount is new, Larry said that 90% of 3rd gens he sees have broken drivers side motor mounts but the passenger sides are ok.
Yep, Fikse FM5 17x10 rear 17x8.5 from with A032R rubber
Old Apr 25, 2002 | 06:53 PM
poss's Avatar
Slower Traffic Keep Right
looks good, but isn't the motor mount heat shield supposed to be on the passenger side, not the drivers side?
nice wheels
Old Apr 25, 2002 | 06:57 PM
vosko's Avatar
Just Call Me Terminator!
day 2 is the reason i have a T78 now
Old Apr 25, 2002 | 07:01 PM
Jedon's Avatar
Slave2TheFD
Yeah just a few hoses hehe. I plan to go single after I pass smog and break in the engine
I'll check the manual about the heat shield, I got the engine back with that and the motor mounts already on.
-Jedon
Old Apr 25, 2002 | 08:26 PM
ttpowerd's Avatar
HARRRRRRRRR
Looking good! What single are you looking at going with? What are your purposes (ie. drag racing, autox, cruising, etc.)?
Nice wheels
Old Apr 25, 2002 | 11:44 PM
Jedon's Avatar
Slave2TheFD
T04 60-1 .7 comp 1.15 A/R P-Trim Divided
AutoX, Road Racing, cruising.
Thanx! I love the wheels, they came with the car, I don't know if I could bring myself to shell out for what they cost new!
-Jedon
Old Apr 25, 2002 | 11:58 PM
suganuma's Avatar
no
isnt that a pretty big a/r to be running for autocross/street?? (1.15 vs 1.00 or .89)
im still learning....someone teach me why im wrong....
Old Apr 26, 2002 | 12:42 AM
Jedon's Avatar
Slave2TheFD
You are not wrong, I might go smaller, just don't want to limit myself.
-Jedon
Old Apr 26, 2002 | 06:40 PM
Jedon's Avatar
Slave2TheFD
Day 3!
http://www.nopro.com/~jedon/engine/day3.html
-Jedon
Old Apr 26, 2002 | 08:02 PM
ziftar's Avatar
Rotor Head
Thanks for the pics! I'm getting the tooling together right now for my very own engine project. You pictures are proving quite useful in seeing what I'm getting into.
Old Apr 26, 2002 | 10:12 PM
Jedon's Avatar
Slave2TheFD
No Problem, I have video and more pictures from when I was taking it apart, eventually I'll get around to putting them all somewhere so people can benefit from my mistakes
I've only snapped the heads off two bolts and broken both oiler lines so far...hehe sure glad I have spares!
-Jedon
Old Apr 27, 2002 | 12:45 AM
turbojeff's Avatar
Do it right, do it once
Jedon,
Looks great. It looks like your keeping the MOP right? The lines are supposed to wrap around the front of the engine, around the water pump basically. Just FYI unless your doing something custom.
Jeff
Old Apr 27, 2002 | 01:16 AM
Jedon's Avatar
Slave2TheFD
Jeff,
Those things have been buggin the hell outta me, you have a picture that shows how they go?
Yeah I'm keeping everything for now.
-Jedon
Old Apr 27, 2002 | 10:53 AM
turbojeff's Avatar
I'll send you an email with the pic, probably won't be a very good one since it is not focused just on those lines. The bad news is you'll have to pull the solenoid rack to get them in the right spot. Basically they run right in front of the two bolts that hold the front lift hook on.
Putting together a FD engine after it's been apart for a few months is a tough job, especially the first time you do it. I've always cheated and had an examplet to look at, by now I pretty much have it memorized Congrats on doing this yourself.
Jeff
Old Apr 27, 2002 | 11:06 AM
Jedon's Avatar
Slave2TheFD
The engine has been apart since August! I wish I had not taken my other one apart so I had one to look at to "cheat"
I did move the lines since those other pics though, I'll post Day4 so you can see if maybe I moved them into the right spot?
Thanx!
-Jedon
Old Apr 29, 2002 | 09:13 PM
Jedon's Avatar
Slave2TheFD
Okay, now Days 4,5,6 are up as well as a help me page of stuff that is not connected or missing in action.
If people could take a look and see what I am missing I would really appreciate it!
http://www.nopro.com/~jedon/engine/day4.html
http://www.nopro.com/~jedon/engine/day5.html
http://www.nopro.com/~jedon/engine/day6.html
http://www.nopro.com/~jedon/engine/helpme.html
Old Apr 29, 2002 | 09:33 PM
suganuma's Avatar
no
ill IM you
Old Apr 30, 2002 | 05:47 PM
Single7's Avatar
Hey Jedon,
Not sure if you've figured those things out yet but for what it's worth:
IMG_5573 & IMG_5574
-- ABS pump bracket - attaches to frame on passenger side
IMG_5569
-- Attaches to oil filler neck
IMG_5568
--Grounds to intermediate housing I believe
Hope this helps. -- Tommy
Old Apr 30, 2002 | 06:02 PM
Jedon's Avatar
Slave2TheFD
Single7,
5573,5574: On the passenger side? I'll look, someone else said it was the AC/PS rear bracket and mounted to the bolt in 5560.
5569: Thanx that's what U thought but it won't reach, I'll just make a longer one with some silicone tubing.
-Jedon
ps. thanx guys, couldn't do it without ya!
Old Apr 30, 2002 | 10:16 PM
Single7's Avatar
Hi Jedon,
Woes is me!!! The few wretched souls such as me left in this world who still have a 56k modem at home cannot be much help to you . I remember seeing a connector (black and single pin) that is connected right at the base to an inch thick harness goes to the powersteering. I'll check again when I get to work in the morning and can pull the picture up again.
5563 - the white connector goes to a sensor on the side of your oil pan. Look from the bottom of your car on the driver side and you should see a wire dangling from the side of the oil pan.
5573 - I'm pretty sure that the part is the ABS pump bracket. The easiest way to find out is to actually go and try and fit on your car. If you still have your ABS pump try and fit that on the bracket. The powersteering bracket actually has the powersteering pump as a part of it and is flat. I'll check the pic again when I get to work. Good luck -- Tommy
Oh yet I remember now - the final two pics on your page - that piece goes to the upper intake manifold on the underside if I remember correctly. I'll check that later also. Laters.
Th0m4s
Feb 26, 2019 02:04 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
