New ECU? Why?
Old Apr 25, 2002 | 08:54 AM
djb's Avatar
djb
New ECU? Why?
I have the following mods.
Two questions:
Do I need to get a new ECU?
If so, why?
Old Apr 25, 2002 | 09:37 AM
Mahjik's Avatar
Mr. Links
I don't think you do. It really depends on your boost. The higher levels of boost you run, the more fuel you need to add to the air/fuel mixture. That is the reason you should add an upgraded ECU.
If you are staying a the stock boost level, then there is really no need to upgrade unless you just want to....
Old Apr 25, 2002 | 10:09 AM
djb's Avatar
djb
Thanks. Next thing for me probably needs to be a boost guage.
Old Apr 25, 2002 | 10:14 AM
95R2-89TII Ground Zero's Avatar
Banned
Everyone should have one of those.
Mahjik's Avatar
Mr. Links
Definitely, they will help out if you ever need to troubleshoot a boost or vacuum problem. I hope you never do though.
Old Apr 25, 2002 | 12:51 PM
C'mon now... a FD have boost problems? Why, that's unheard of
Old Apr 25, 2002 | 12:53 PM
mightyslash's Avatar
Will Work for Ferrari
Get a fuel pump.
Old Apr 25, 2002 | 01:46 PM
rynberg's Avatar
You should definitely get a boost gauge to make sure you're not boosting too high and for troubleshooting.
With a stock ecu, you should probably not boost more than 11 psi, I think 12 psi would be pushing it. Depending on YOUR car, you might need to install larger restrictor pills or use a boost controller but probably not.
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
