Old 03-18-08, 11:15 PM   #1
boost_its_what_for_dinner
RotoriousRx7
boost_its_what_for_dinner's Avatar
been wondering this for a while now?
so when datalogging and you are watching the index's of rpm h and l and the the t index and all that ....
my question is what does the 1 2 3 4 mean ? i have a small lean spot between 2k-2800 at light throttle but 4th and 5th gear only like say 40mph in 5th gear if you give x amount of gas it will go lean to about 15.5ish? so i have narrowed it down and changed the fuel % in all vacuum point at 2k and 2500 but still no fix? ill try and load a log.
dont understamd why my wbo2 is showing as analog not afrs?
87 T2 : RR rebuild/SP/JHB jugs : gt35r .82 t4 : 720/1600 : 3"full exhaust : Walboro 255 : big Fmic : KOYO rad./16"e-fan : Greddy Profec b : Apex i bov : uego wb02 : E6X : premix
boost_its_what_for_dinner is offline   Reply With Quote
Old 03-19-08, 12:50 AM   #2
turbo2ltr
From the manual:
Table Indexes
The two table index parameters allow you to log the X and Y index into the respective map. This is
useful to easily see where to make changes in a table. If the Fuel Table index is checked, you will see
two additional parameters being logged, one for the RPM index and one for the boost index. These
number relate directly to the rows and columns of the fuel table.
The Timing table index, when selected, will log either two or three parameters depending on the ECU:
The load index of the timing table, and one or two RPM indexes. On the N332 ECU, the T-Indx RPM L
relates to the 13 cells from 0 to 4096 RPM. Values will be 0 to 12. The T-Indx RPM H relates to the 7
cells above 4096. Values will be 0 to 6. All other ECUs only have one T-Index RPM parameter
representing the full range of the timing table columns.
Did you set up the WB02 scaling in the viewer?
turbo2ltr is offline   Reply With Quote
Old 03-19-08, 01:02 AM   #3
RotoriousRx7
yes its setup but sometimes i have to check it sometimes and just set it up again sometimes
thanks
Old 03-21-08, 12:16 PM   #4
The Wankler
FKITALL
The Wankler's Avatar
Trader Score: (8)
I as well have a funny lean spot around 2500-2800.
1988 TII 13bt StreetPort, RTEK 2.0 720cc secondaries
T4 Garrett Hybrid by Rotaryshack. Apexi Dual Chamber BOV, HKS filter, Apexi Dual N1, greddy fmic, koyo radiator, act extreme clutch, Act Light Steel flywheel, Innovate LC1 Wideband. Greddy EBC.
The Wankler is offline   Reply With Quote
Old 03-21-08, 03:26 PM   #5
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
me too, i have an extra 10% added in that area so that it doesnt stumble. but when it doesnt stumble it is too rich
gxl90rx7 is offline   Reply With Quote
Old 03-22-08, 01:13 AM   #6
RotoriousRx7
alright then im not a dumb ass then...
but i never use the table version of the fuel map i just use the bar graph
Old 03-22-08, 01:53 AM   #7
rogrx7
Turbovert done.
rogrx7's Avatar
1 volts?
2 volts?
3 volts?
4 volts?
I think u have to go into ATP and do the multiplier junk
rogrx7 is offline   Reply With Quote
Old 03-24-08, 12:07 AM   #8
RotoriousRx7
ummm i have the aem uego.... its a preset...
Old 03-24-08, 01:08 AM   #9
rogrx7
Turbovert done.
rogrx7's Avatar
What does the Uego have do with what the Rtek reads
Old 03-24-08, 02:07 AM   #10
RotoriousRx7
when you set it to the preset for the aem uego u dont have to put in the multiplier info.. it does it for you....so you go to input and click the box for atp and then set it up by picking the aem in the preset list???
Old 03-24-08, 01:28 PM   #11
The Wankler
FKITALL
Trader Score: (8)
You only get this hesitation while lightly revvvvving from 2500-3000k?
Old 03-26-08, 03:24 PM   #12
RotoriousRx7
well i found it betwwen the 4/3 and 4/4
4 fuel /3 boost
4 fuel/ 4 boost
that is how that table goes right?
b 4
o 3
o 2
s 1
t 0
0 1 2 3 4
f u e l
but i know that the negatives are there but just trying to make sure thats ho its laid out?
i was wondering!? cooliomo Race Car Tech 5 01-16-06 06:54 PM
wondering tasteyspoonz 2nd Generation Specific (1986-1992) 5 01-12-06 11:28 PM
just wondering VaGambler 2nd Generation Specific (1986-1992) 3 01-03-06 07:52 AM
Just wondering sixstar Rotary Car Performance 2 09-27-04 05:03 PM
I am wondering about something Sprockett 3rd Generation Specific (1993-2002) 13 08-19-03 12:16 PM
