Microtech 5500 rpm problem
Old Mar 15, 2008 | 07:36 PM
jon4825's Avatar
Jon R.
5500 rpm problem
I have a single turbo conversion with my FD. I currently run a LT8. My tuner did a street tune, but when I accelerate past 5500prm it supters to the point where it is almost like a rev limiter. I am able to get to 6500 - 7000 in 1st gear without this problem thought. Any suggestions?
Old Mar 16, 2008 | 11:12 AM
dean23's Avatar
pwned
are you monitering the afr's? what do they say? is it only under heavy load (can you slowly creep past w/o any problem?)
Old Mar 16, 2008 | 04:37 PM
BluRR's Avatar
its always best to post your map here so that we see if you have any funky values. Please post the options map for the staging as well.
Old Mar 16, 2008 | 04:44 PM
rx72c's Avatar
Top Answer: 1
I reckon in the heavier gears its loading the engine up more and hitting a point in the map which hasnt been tuned and is either rich or lean.
you need to check your afrs, or better yet take it back to your so called tuner.
Old Mar 17, 2008 | 08:23 PM
jon4825's Avatar
Jon R.
I'll get the maps up soon. thanks fo the help
Old Mar 18, 2008 | 05:23 PM
rx72c's Avatar
Top Answer: 1
great. Interesting to see them.
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 7, 2015 10:21 PM
rx7shirley
Sep 2, 2015 02:11 PM
