LS1 Coil Limitations?
Old Mar 10, 2008 | 02:17 PM
fritts's Avatar
Mad Man
I have seeing quite a few LS1 coil threads lately and was wondering how far these coils have been pushed on a rotary. They would work for a rather neat and compact install for my sequential ignition setup and was considering them for use. I plan on running E85 out of a T04R at 20-24 psi. Will they be up to the task?
Old Mar 10, 2008 | 03:45 PM
mazpower's Avatar
Slizzard sippin sizzurp
I run two MSD LS1 coils for my leading & two standard LS1 coils for my trailing. Half-bridge 13B-REW, Turbonetics T-66 @ 23 psi of boost with 20% aux methanol injection. No breakup all the way down to 10:1, B10EGV plugs all around. I run mine at 5 ms charge time.
Old Mar 10, 2008 | 04:06 PM
fritts's Avatar
Mad Man
Do you think the MSD LS1 coils are giving you much benefit over the standard ones?
Old Mar 11, 2008 | 02:29 PM
mazpower's Avatar
I was experiencing some breakup with the stock LS1s on the leading side, it was at lower boost and with a very conservative timing curve. Looking back, I probably could have eliminated the breakup with more timing, but I opted to go with the MSD coils and it cleared up the breakup instantly. They're $80 a piece and I figured I'd need them to achieve my eventual power goals. They're pretty beefy, almost double the width of the stock LS1 coils. At some point I plan on upgrading my trailing coils to the MSDs as well.
Considering the boost level and fuel you're planning on using, I'd recommend the MSDs at least for the leading. Or you can try the standard coils and if you get breakup, upgrade to the MSDs.
Old Mar 11, 2008 | 02:51 PM
enzo250's Avatar
IRS Champion
MSD's are definitely stronger then the stock ls1 coils..
I have used them on a couple of engines that were beginning to misfire with the
ls1 coils and now run much better with MSD's.
Old Mar 11, 2008 | 04:31 PM
C. Ludwig's Avatar
www.lms-efi.com
Enzo, has Lance ever setup that test of his coils versus the LS1 and MSD coils?
Old Mar 11, 2008 | 05:46 PM
enzo250's Avatar
IRS Champion
No. He seems to only care about his own coils.. He pushes them to death..
I figured i'd put him on the spot so he could prove how good his coil really is..
I swapped LS1 to MSD coils and the car (TT VIPER) runs much better and doesn't miss anymore. What i like about the MSD Coil also is we can now also use a CDI and bypass the built in igniter... So the coil can be used either way...
Only downfall is that its not cheap...
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
dillrx7
Sep 7, 2015 09:38 AM
