spark boost
Old Mar 9, 2008 | 10:11 PM
rdachelet's Avatar
spark boost
i am installing the apexi rx6 single turbo and was wondering if any one recomends some sort of ignition system and what do you think of the kenne bell spark boost
Old Mar 9, 2008 | 10:38 PM
mono4lamar's Avatar
In the burnout box...
Kenne Bell who? You can build your own ignition system! It all depends on budget...
Old Mar 9, 2008 | 10:40 PM
Busted7's Avatar
Will work for horsepower
The twin power is working for me and quite a few others.
Old Mar 10, 2008 | 06:46 AM
rdachelet's Avatar
this is about the last thing i need so have little mpney
Old Mar 10, 2008 | 12:00 PM
j-specfd3s's Avatar
i have the rx6 turbo set up also, i am running a jacobs fc1000, its a nice ignition amp look in to it.
Old Mar 10, 2008 | 12:09 PM
XS Engineering makes an amplifier as well.
Old Mar 10, 2008 | 12:33 PM
classicauto's Avatar
Crash Auto?Fix Auto.
The kenne bell IGN is *decent* as in, I know a couple guys running it (boinger engines) and heard of no trouble. But I have no idea what their system actually consists of as far as whether its an actual amplifier or not however.
Old Mar 10, 2008 | 12:46 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
you don't need any ignition mods w an RX6. just make sure you have good spark plug wires and run 9s or 9 and 10 plugs.
the RX6 is a wonderful turbo but doesn't move enough air to challenge the FD elec system.
i just saved you some money
howard coleman
Old Mar 16, 2008 | 04:50 PM
BluRR's Avatar
When do you think the stock system gets challanged? What boost or power levels and also what conditions?
Old Mar 17, 2008 | 07:57 PM
my guess is you can run 410 rwhp w the OEM ignition as long as the plug wires and sparkplugs are fresh.
if you are running water injection probably not...
hc
rgordon1979
40
Mar 15, 2022 12:04 PM
windom
Sep 11, 2015 04:48 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
