brakes
Old Apr 23, 2002 | 01:29 PM
firstRX-7's Avatar
brakes
I just got the results back from my safety test and I failed because all my brakes are shot. Is there any way to get a set of GSL-SE rear disks on my 83???
Old Apr 23, 2002 | 01:39 PM
riffraff's Avatar
smog nazi destroyer
you could swap in the entire rear end.
not that hard to do as far as i know.
Old Apr 23, 2002 | 01:49 PM
peejay's Avatar
Old [Sch|F]ool
Yes, just bolt the rearend assembly in, swap e-brake cables, flex hose, and rear wheels. You can even keep your '83 driveshaft!
Old Apr 23, 2002 | 01:52 PM
riffraff's Avatar
smog nazi destroyer
if you do that, i would go ahead and swap the front breaks in too. that way you get those better breaks, and so that you have the same bolt pattern on the front and rear.
Old Apr 24, 2002 | 11:39 PM
firstRX-7's Avatar
what would I have to do to put all four GSL-SE brakes on my car????? disks I mean......obviously.
Old Apr 24, 2002 | 11:44 PM
peejay's Avatar
Old [Sch|F]ool
for the front you need the strut assemblies with rotors and calipers. and of course different wheels and tires...
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
