Rebuild Carb Kit & Instructions
Old Apr 22, 2002 | 09:17 PM
SuperPhly's Avatar
If I were to purchase the rebuild kit and take my carb to a guy to work on would he need any special instructions? My car sat for a while and it needs to be cleaned and rebuilt... 90% of my problems point to it... everything else in the fuel system is new (filter, pump, etc). Anyway, does he need any special instructions or numbers to work on it? or is a carb is a carb is a carb?
Also, how much is a new carb for my 12a? Would it be better to just buy a new one? or is it much cheaper to rebuild mine?
I want a pro to do it if possible (I am not that good with carbs, nor do I have the time to not have a car for a few days... college student and such).
Thanks.
Old Apr 23, 2002 | 04:44 AM
REVHED's Avatar
Hunting Skylines
I rebuilt mine a while ago and there's really nothing to it.
Now, this is just a suggestion and I realise this might not be possible due to the reasons you mentioned. But, wouldn't you gain alot more satisfaction in doing this yourself? Not to mention save some money and maybe learn a little about carbs in the process? All it takes really is some basic mechanical skill and a bit of common sense. Plus you can always ask for help here.
If you do decide to take it somewhere they should be able to do it in a day easy.
Old Apr 23, 2002 | 05:56 AM
4ohfour's Avatar
Just take a looky at the haynes manual and the documentation provided with the rebuild kit.
I am sure that if those 2 options turned up nothing, you could perform a search with any reputable search-engine and yeild some results.
Here is a good place to, good luck soldier!
cheers'
Old Apr 23, 2002 | 08:15 AM
jeremy's Avatar
male stripper
i did mine last week and i'm an idiot with carbs. i had a pin and a mystery spring that wasn't shown in the haynes or the rebuild kit exploded assembly but it runs. overall it might have taken me a full day on it including soaking in carb cleaner/gas but i let mine soak for a couple of days.
Old Apr 23, 2002 | 04:33 PM
SuperPhly's Avatar
What I may do is go pull one out of a bone yard, and bring it home and do a good job over a week or so... soak it for a while, and take my time... asking questions etc.. thansk
Old Apr 23, 2002 | 04:45 PM
hanman's Avatar
It is a basic four barrel carb. No big deal.
Don't even think about buying a new one. $1000.00, how's that for spendy?
Buy a good carb kit from Mazdatrix or similar. The problem with the ones from the parts store, they are a "one size fit's all" type of kit. You end up with lot's of extra parts that can be confusing to the first time rebuilder. Just my opinion.
hanman
Old Apr 24, 2002 | 12:48 AM
SuperPhly's Avatar
Hmmm, ok... anyone have a stock 12a carb they are willing to sell me? Cheap?
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
ncds_fc
Aug 15, 2015 10:06 AM
