+1 on the Rtek 1.8 or 2.1. I personally prefer the 2.1 for its tuning abilities and adjustable fuel maps. There's most likely someone selling a 2.0 or 2.1 setup/ECU in the for sale section, Its worth checking out. Otherwise its about 300 for a brand new tuned 2.1 ECU from pocketlogger.com and a PDA to run it is not that expensive depending on what band and style you get. The 2.1's allow you to change the injector sizes with the software very quickly instead of buying another ECU like the 1.7/1.8. That and the 2.1 lets you see real time data on what your engine is doing, its very useful for tuning the engine just right. You'll probably need a wideband in the long run too so consider getting one of those too. Good Luck
