grinding sound
Old Apr 22, 2002 | 01:01 AM
marshp's Avatar
Registered Rx7 Owner
grinding sound
im not too sure of my problem but it seems about every 3rd time i try to start my engine on my 85 rx7 gs it makes like a grinding noise and then i try again and then it works... its also a manual tranny if that makes a diff. which i think it might.. im not sure it could also be likely to be something to do with the starter cause thats my guess... do you think i need a new starter or what could be my problem.. any help is wanted thanks!
Old Apr 22, 2002 | 01:40 AM
RotorMotorDriver's Avatar
Seven Is Coming
My newest car (84 GS) was making an odd grinding noise also, and I traced it down some kind of electric motor attached to the choke assembly (choke doesnt work anyway) thing in the engine bay. It sounded all the world like stripped teeth on the flywheel or something, but it was that damn motor. It had one wire going to it, so I pulled it, hit the key and no more grinding. Maybe the same for you...
~T.J.
Old Apr 22, 2002 | 04:40 AM
yayarx7's Avatar
Are you Nucking Futs?
Sounds like a tooth on your ring gear is worn/broke. and when that section is engageing your starter, it is grinding, could be your starter though. You can pull the starter and take it to a auto parts store and have it tested, the ring gear can be inspected while the starter is out of the car.
Old Apr 22, 2002 | 07:08 AM
85RX7GS's Avatar
I had the same problem and it turned out to be a bad solenoid (mounted on the starter). It might not be a bad idea to check your battery cables also.
Old Apr 22, 2002 | 08:44 AM
WackyRotary's Avatar
standard combustion
That starter grinding noise if common, just let it stop spinning on its own and try again and it won't grind. This is a temp/perminant fix to that depending on budget.
Old Apr 22, 2002 | 09:50 AM
jeremy's Avatar
male stripper
mine does that too if i try to turn it over a few times in a row. as long as it still turns over i don't care. i cringe everytime it happens though.
Old Apr 22, 2002 | 02:30 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
More than likely its the starter, the teeth on the starter arent near as tough as the flywheel
Old Apr 22, 2002 | 08:32 PM
smnc's Avatar
EliteHardcoreCannuckSquad
~T.J.
That's the hot-start-assist system...
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
