single turbo, size? response?
Old Feb 17, 2008 | 03:13 PM
R-R-Rx7's Avatar
Rotor or no motor
hey guys
i ve been thinking to upgrade my stock 2002 turbos to something bigger starting from the hf420, bnr twins etc because they are a lot quicker than a large single turbo.
i ve been thinking and thinking about it thought.
any single turbos that are quite quick on the response?
i ve seen in the for sale section the greddy t78 turbo kit,
any feedback on it??
any other recommendations to be capable around 500-600hp and quick?
Thank you
Con
Old Feb 17, 2008 | 03:48 PM
rx72c's Avatar
Top Answer: 1
Get.
A GT35/40(With the 88mm Inducer, and 62mm inducer) With a 1.06 Housings. Short Runner Manifold(1 3/4 ID Pipe). 60mm wastegate.
You will have 15psi just under 3500rpm, and power still start to drop off over 8000rpm(Not that you will notice it on the street).
This is the best Street package i have ever seen. I have done a few FDs here in australia with this setup and all make around 400RWHP at 15psi.(So around 440rwhp up your way due to conditions).
The above setup has alot of midrange torque.
If your interested in a kit, pm me. I make and sell turbo kits for all rotaries and i can supply the above.
Old Feb 19, 2008 | 10:14 AM
makhna's Avatar
Canadian Eh!
How much would something like this set me back by? Including shipping to Vancouver, Canada?
Thanks
Old Feb 20, 2008 | 10:41 AM
RroamD's Avatar
RE ONLY
I use this one with stock port, boost set up at 1 bar. The boost start at 2000 rmp and full at 3000 to 6500 rpm. This turbo can run the max. 600 RWHP with porting engine.
https://www.rx7club.com/single-turbo-rx-7s-23/post-your-single-turbo-setup-33502/page16/
Old Feb 25, 2008 | 09:07 PM
Fishey's Avatar
Porsche ***
https://www.rx7club.com/showthread.php?t=33502&page=16
Yea, I don't see that happening at any point.
sherff
Feb 24, 2019 12:09 PM
