WoooHoooo! Dynotune results!
Old Apr 20, 2002 | 06:56 PM
History:
Ran in Indy 3 weeks ago without a wideband, so did no S-AFC tuning:
169 RWHP 201 lb/ft Torque
Sought help from the guys on this forum....
Added Walbro,Bonez DP, and High flow cat
Today tuned with wideband O2:
229.7 RWHP 228.9 lb/ft Torque (running 11psi)
A HUGE thanks to all who gave me guidance!!!
Mike
Old Apr 20, 2002 | 06:57 PM
RETed's Avatar
NICE!&nbsp Congrads!
-Ted
Old Apr 20, 2002 | 07:06 PM
damn hippies
is the main hp gain b/c of the 11psi or no
Old Apr 20, 2002 | 07:11 PM
My assumption is that freeing up the exhaust was the main factor. The stock cats were restrictive and choking the flow, thus poor power. The 11 psi I'm running is solely due to the upgrades in intake and exhaust.
The mods that I had done previously were not helping until I could get the exhaust to exit more freely. I would not expect that simply bolting on a downpipe and high flow cat would give you anywhere close to a 60 hp gain. Tuning fuel ratios helps quite a bit as well!
Mike
ponykiller's Avatar
60 hp gain?!?!?!?!?! SWEET!!!
Kris
Old Apr 20, 2002 | 07:27 PM
Scott 89t2's Avatar
SOLD THE RX-7!
what was your power before you started tuning?
Old Apr 20, 2002 | 07:39 PM
221.0 RWHP 218.3 lb/ft
Didn't spend time fine tuning.
4 pulls, just really adjusted 5k - 8k down about 6% ave.
12:1 up to 5k, then about 11.3:1 up to 7200.
Mike
Old Apr 20, 2002 | 08:03 PM
nocab72's Avatar
03 Cobra Killer
Nice runs Mike! I got them all on video so you can watch them over and over while you continue to smile!!!
Old Apr 20, 2002 | 09:15 PM
Bambam7's Avatar
I came, I saw, I boosted.
Is the richening to under 12:1 at high RPM's for safety's sake? ie, would you have a little more power running at 12.1 all across? Because I know N/A's make more power running almost 14:1 up high, and about 12.8:1 in the midrange.
So at no point were you adding fuel? Cool. Your car mustave been running pretty rich.
Old Apr 20, 2002 | 09:53 PM
Are you running the stock TURBO? My ratings are 300 FWHP with the HKS SPORT TURBO UPGRADE KIT, Which actually is just a bit better than the stock Turbo.
Old Apr 20, 2002 | 10:02 PM
yup,stock turbo!
BTW, I went to G.C.Marshall High School near Tysons Corner!! (many moons ago)
Mike
Old Apr 21, 2002 | 02:53 PM
chatch's Avatar
Dude 230 lbs. of torque, thats sweet! What rpm's did you hit max torque at? I have almost the exact setup as you and I'm dying to get mine on the dyno.
-Matt
Old Apr 21, 2002 | 03:24 PM
peejay's Avatar
Old [Sch|F]ool
WOW! Glad to see you found all that missing power!
I foresee new sticky tires in your future...
Old Apr 21, 2002 | 04:52 PM
billzrx7's Avatar
Yah i witnessed mikes horrible dyno run at indy, it didnt help him any to see mine pull 224.2 HP and 211.2 ft/lb torque. Altho all i have a midpipe, intake, j spec motor. (still have t hat cat in the DP) and no tuning done. but im glad to see mikes finally gettin numbers out of his motor.
and mike...
I TOLD YOU GET THAT DOWNPIPE!
Old Apr 21, 2002 | 05:58 PM
Rx-7Addict's Avatar
Rotary Powered
Wow! Over 60 hp gain from those few mods
Adding the DP and free flow cat obviously also helped the other mods work more efficently
billz: mike was telling me how jealous he was!
nice car mike
Old Apr 21, 2002 | 06:34 PM
vosko's Avatar
Just Call Me Terminator!
good work
Old Apr 21, 2002 | 08:44 PM
dre_2ooo's Avatar
Old Apr 22, 2002 | 07:25 AM
chatch,
My torque curve was basically a flat line. I hit 227 lb/ft @ about 3100 rpm. peak was a tiny jump to 229 lb/ft at about 4200 rpm.I didnt drop below 225 lb/ft until after 5200 rpm. (just from memory)
I'll post a scan of the dyno slip shortly.
Old Apr 22, 2002 | 08:16 AM
Josepi's Avatar
Despise Enmity
What brand of HF cat ya using?
Old Apr 22, 2002 | 08:25 AM
Bonez turboflo system: DP and HF cat
Old Apr 22, 2002 | 08:38 AM
Grimlock's Avatar
Talking cool dude...congrats!
can you post your safc numbers?
Old Apr 22, 2002 | 07:53 PM
Here's the Dyno sheet!!
Like the torque curve??
Mike
Old Apr 25, 2002 | 07:50 PM
Mr Rotary's Avatar
Curry Power
Excellent work done. I'm a new owner of a 87' Base FC and already I'm learning a whole lot of new things (definitely can't say a couple ). Keep up the good work
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Shainiac
Jul 17, 2019 02:20 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
