FD original engine compression results at 140K
Old Apr 20, 2002 | 05:17 PM
Want2race's Avatar
Bigger and better things
got any dyno #'s???
Old Apr 20, 2002 | 06:10 PM
turbojeff's Avatar
Do it right, do it once
How do you know it is the original engine? If you didn't buy it from the original motor then you can't be sure it hasn't been replaced. A friend of mine bought a 93 Touring w/56K from the dealer, advertised as original motor. When he had a boost problem I pulled the upper intake and there was this "Mazda Rebuild" sticker on top of the "block".
Also what "seals" did they replace when the car was overheated? There aren't really any to replace without rebuilding the motor. If it lost coolant it was either a AST that split, or some water hose. None of those I'd call a "seal".
I think you need to clarify a few things...
Great compression numbers though!
Old Apr 20, 2002 | 06:12 PM
mightyslash's Avatar
Will Work for Ferrari
Exactly.
Old Apr 20, 2002 | 06:31 PM
Malachi151's Avatar
from Children of the Corn
Well, congtrats on a good deal, and nice motor firstly.
Secondly though my engine was replaced at 70,000 miles due to an overheat, and I did not try to drive my car at all. When it overheated I stopped, parked it, and walked home and picked it up later.
Why did it overheat? The Thermostat had gotten stuck.
Is that really a part of poor maintance? I dunno. Most cars don't need a new thermostat before 100K miles so it wasn't something that I thought about changing out for no reason. In retrospect, and knowing what I now know, I'll probably change out the thermostat every 50K miles.
Also, was the number that you quoted, 2400 the cost fo teh "seal replacement"? Because that is about what it costs to rebuild a motor, so it sounds to me like the motor had been rebuilt.
Old Apr 20, 2002 | 07:09 PM
Malachi151's Avatar
You can buy a remanufactured motor(essentially new, sometimes better then new) for under $2,000, and the labor to install it is about $1,000.
You should be able to get your engine pulled, get a new motor(reman) , and have it installed for under $3,000 if that is all that is needed.
Old Apr 20, 2002 | 11:41 PM
j9fd3s's Avatar
Community Builder
only mazda remans leak from the front cover....
mike
C. Ludwig
Jan 30, 2019 06:31 AM
elfking
Aug 19, 2015 09:48 PM
