ceramic coating make a difference?
Old Feb 4, 2008 | 09:08 AM
darkside7's Avatar
Question ceramic coating make a difference?
I'm trying to figure out if ceramic coating will make a difference? (ie down pipe, mami, and turbo hotside)
Old Feb 4, 2008 | 09:54 AM
David Hayes's Avatar
It should be an alternative to thermal wrap and should work the same. We'll see for me. I just swapped out the wrap for ceramic coating. I'll let you know.
Old Feb 4, 2008 | 08:13 PM
It makes a huge difference in my opinion.
I recently turned out a customer's car with a T04Z turbo and no coating.
Compared to my setup, with 3600 degree cerama-black on the mani/dp/turbine housing, the amount of engine bay heat at idle and after some easy driving was unreal.
Supposed to help spool as well, hard to quantify that.
The coatings that my guy does are specifically formulated to handle the high EGTs that the rotary engine generates......
P.S. David, might be time to change your sig to 'Gotham 20b conversion'
Old Feb 4, 2008 | 09:11 PM
justturbo2's Avatar
Registered User
hey rich does your guy have something for the lower intake manifold. does it make a difference, in your opinion. also how much? sorry so many questions.
thanks justin
Queppa
Nov 18, 2024 03:47 AM
astrum
24
Nov 15, 2017 08:44 AM
primerGrey
Aug 25, 2015 02:46 PM
