Originally Posted by RickRx
with my setup should I also use the safc in combo with the 2.1? thanks
as said- no, there is no reason to use any extra device if youve got the 2.1
the 2.1 is acts almost like a standalone, has many, many programmable parameters.
you dont need to do any baseline tuning or setup to JUST get it running like you do with a haltech.
to install it and get it working correctly, remove all your haltech stuff, and re-install the modified 2.1 ECU. essentially it should look like stock, except you will have a PDA attached to it to tune with. you dont need to make a new harness, or install other weird boxes here n there. remove all the old crap, and basically go back to stock.
this is why many ppl like the 2.1 over standalone, because you dont have to re-wire everything and make custom mounts, cooling fans, etc for aftermarket stuff. just plug the modified ECU into where the stock one was and youre done.
if you have a S-AFC, sell it. it is useless with the 2.1, seeing as the 2.1 can accomplish anything and everything the S-AFC can, and do it 5 times better. comprende?
