Differential gear change & speedometer
Old Apr 19, 2002 | 12:05 PM
Rail Head's Avatar
I'm thinking about replacing my 3.90 differential in my automatic and installing the 4.10 diff from a manual. Obviously this would change the speedometer and odometer readings. Does anyone know if there is some existing dip switches or something to change the speedometer set up from auto to manual?
Old Apr 19, 2002 | 02:11 PM
Freaky Monkey007's Avatar
To change the speedo i believe there is a gear that you have 2 order and get changed. I could be wrong as i have no idea if this is the case with the FD but i know that when i was looking around for cherokees with lifts you had 2 order a new gear for it... Wouldnt changin the gearing mess up the automatic since it will be at a different rpm range when shifting?
Old Apr 19, 2002 | 02:32 PM
pomanferrari's Avatar
order from dakota digital a black box (model dd-sig2 i think) that can intercept your speed signal and reconfigure it so that the speedo will read correctly. price is about $100.
Old Apr 21, 2002 | 04:06 PM
Rail Head's Avatar
Pomanferrari
Hi thanks for the lead on Dakota.
Rail Head
The1Sun
Sep 15, 2015 04:45 PM
kkev.7788
Sep 2, 2015 01:32 PM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
