Old 01-25-08, 01:23 PM   #1
10thaniv
10thaniv's Avatar
Stock O2 sensor needed?
I'm getting the 2.1 ECU and I also want to install a wide band sensor and controller. Can I remove the stock sensor and install the wide band sensor in its place, or do I need to have an extra bung welded to my down pipe and run 2 sensors?
1982 RX7 sold.
1984 GSL-SE sold.
1994 SHO sold.
1997 GTP sold.
2000 SE-XE Xterra DD.
1988 10th RX7 weekend fun.
10thaniv is offline   Reply With Quote
Old 01-25-08, 02:13 PM   #2
boostedfc3s
1.3 liter piston eater
boostedfc3s's Avatar
My wide band ( which is the AEM ) said to put the sensor about 30" to 36" down stream from the turbo because of the heat generated from the turbo. So I had to add a bung for the wide band. I'm not sure about other brands of wide bands though. As far as the stock O2 sensor I have no clue so I'm not gonna guess, but I'm sure someone from DTI knows.
1987 Turbo II. Atkins stage 2 street port w/3mm seals. 60-1 turbo,FMIC,dual pumps,720cc/1680cc,Power FC with Banzai harness. Steve Kan tuned @ 17 psi 352RWHP/296 torque.
boostedfc3s is offline   Reply With Quote
Old 01-25-08, 03:18 PM   #3
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
you need a 0-1v (narrowband) o2 sensor for the ecu to go into closed loop cruise, it will run fine without it, but you will have worse gas mileage
most wideband controllers also have a 0-1V output intended for the stock o2 sensor input, but like boosted said if you put the wb sensor in the stock location it will get too hot and have shorter lifespan
I left the stock o2 alone, and had a second bung welded in just before my presilencer, have had no problems. make sure it is on the top of the pipe though, so that water doesnt collect in it
gxl90rx7 is offline   Reply With Quote
Old 01-25-08, 06:02 PM   #4
turbo2ltr
Please read the sticky!
http://www.rx7club.com/showthread.php?t=577999
turbo2ltr is offline   Reply With Quote
Old 01-28-08, 12:56 PM   #5
10thaniv
10thaniv's Avatar
Thanks Everyone. I will keep the stock O2 sensor and have another bung welded down stream for the wideband.
1982 RX7 sold.
1984 GSL-SE sold.
1994 SHO sold.
1997 GTP sold.
Will PLX Wideband SM-AFR Sensor Fit In Stock O2 Sensor Location? Hex7E 2nd Generation Specific (1986-1992) 3 06-11-07 01:15 AM
Pressure sensor needed? dwb87 2nd Generation Specific (1986-1992) 3 03-21-07 02:58 AM
02 sensor needed? westcoasttuner Power FC Forum 8 09-12-05 11:39 PM
