Megasquirt FC Intake manifold Vacuum ports :S???
Old Jan 24, 2008 | 09:08 PM
Jobro's Avatar
SAE Junkie
What do these do?
Can I just block them in an aftermarket fitment?
Old Jan 24, 2008 | 10:35 PM
gross polluter's Avatar
The ports closest to the secondary injector bungs and oil injector plugs are from air bleeds on the throttle body. It just injects air around the injectors to help atomize fuel.
The port that comes off the primary runners at an angle is the nipple for the FPR.
Old Jan 25, 2008 | 12:30 AM
Jobro's Avatar
SAE Junkie
If I'm using a sard aftermarket regulator do I still use the angled port?
Also, how do I setup the air bleeds? where do they get air from?
Old Jan 25, 2008 | 12:46 AM
All of the air bleeds are on the upper intake manifold, right behind the throttle body facing the firewall. Depending on what upper intake manifold you have you will have either 1 or 2 small ports and a slightly larger port that connects to the oil injectors, for those that still have them.
As far as the FPR, you can take the source from the stock location.
Old Jan 25, 2008 | 12:51 AM
Jobro's Avatar
SAE Junkie
I'll get a photo of the upper as well because theres a few unknowns there.
Not using oil injectors.
C. Ludwig
Jan 30, 2019 06:31 AM
Engine stand ready
Aug 14, 2015 10:26 PM
