Old 01-24-08, 01:37 AM   #1
boost_its_what_for_dinner
RotoriousRx7
boost_its_what_for_dinner's Avatar
2.1 users
so anyone using this yet feed back thread right here
87 T2 : RR rebuild/SP/JHB jugs : gt35r .82 t4 : 720/1600 : 3"full exhaust : Walboro 255 : big Fmic : KOYO rad./16"e-fan : Greddy Profec b : Apex i bov : uego wb02 : E6X : premix
boost_its_what_for_dinner is offline   Reply With Quote
Old 01-24-08, 02:06 AM   #2
turbo2ltr
I just put it up today, no one's going to have it... except edomund. He's had it for the past month and a half or so.
Got several orders today though...so soon enough..
turbo2ltr is offline   Reply With Quote
Old 01-24-08, 11:14 AM   #3
The Wankler
FKITALL
The Wankler's Avatar
Trader Score: (8)
Yep, ordered mine.
1988 TII 13bt StreetPort, RTEK 2.0 720cc secondaries
T4 Garrett Hybrid by Rotaryshack. Apexi Dual Chamber BOV, HKS filter, Apexi Dual N1, greddy fmic, koyo radiator, act extreme clutch, Act Light Steel flywheel, Innovate LC1 Wideband. Greddy EBC.
The Wankler is offline   Reply With Quote
Old 01-24-08, 04:12 PM   #4
RotoriousRx7
me too ya my bad when i posted this i i just got done looking at something from last month on the 28th and thought thats what day it was ....blonde moment
Old 01-29-08, 06:07 PM   #5
turbo2ltr
So anyone get it yet?
Old 01-29-08, 06:46 PM   #6
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
tracking says thursday.. dammit i cant wait that long!
gxl90rx7 is offline   Reply With Quote
Old 01-29-08, 09:48 PM   #7
rogrx7
Turbovert done.
rogrx7's Avatar
Just place my order for the upgrade
rogrx7 is offline   Reply With Quote
Old 01-30-08, 01:12 AM   #8
RotoriousRx7
i got mine yesterday and installed in a breeze. hesitation from cruise vacuum ELIMINATED... WOOT
but i have no clue as in timing for boost based so i have the stock timing for now
now just tuning but seems to be alott easier now that stumble is gone and wider rpm range
Old 01-30-08, 01:40 AM   #9
95nracer
Actual size
95nracer's Avatar
I won't get it until friday.
Are the map based timing settings blank or are the stock settings there to work around? I'll have to see how the map is setup before I start making some changes.
I plan on setting mine up something like this:
Boost/vac-------Lead timing advanced
14__________16
13__________18
12__________19
10__________20
9___________21
8___________22
7___________23
6___________25
5___________27
4___________30
3___________32
2___________33
1___________34
0___________35
-5___________35
-10__________35
-20__________25
-25__________25
-30__________25
And split something along these lines:
0500 ... +15
1000 ... +15
1500 ... +15
2000 ... +14
2500 ... +12
3000 ... +10
3500 ... +10
4000 ... +10
4500 ... +10
5000 ... +10
5500 ... +10
6000 ... +10
6500 ... +10
7000 ... +10
8000 ... +10
But I don't know if I want to get that aggressive with the split up top.
I have to do more reading on how far advanced I can go during vac and low pressures. I'll see if I can find more base maps from other people.
If someone has a suggestion please post up!
12.1@114
95nracer is offline   Reply With Quote
Old 01-30-08, 09:14 AM   #10
gxl90rx7
breaking stuff
gxl90rx7's Avatar
i have a question about the staging hesitation fix.. do the secondaries now turn on above a certain load if above the staging rpm? vs positive boost like before?
Old 01-30-08, 09:38 AM   #11
turbo2ltr
Correct
Old 01-30-08, 09:40 AM   #12
turbo2ltr
From the website.
The user can turn this feature on to convert the timing tables to PSI vs RPM which provides better control over timing above 10 PSI as compared to the stock Load vs RPM. This mode is NOT for beginners. It requires complete manual remapping of the timing tables as the stock tables are no longer valid. The ECU is shipped with MAP Based Timimg mode turned off, so the ECU uses the stock timing maps (Load vs RPM) which can be edited by the user.
The mode only changes how the ECU does the lookup on the table. It does nothing with the map. SO if you put it in boost based timing mode, you will be reading off the load based timing map, which is not a good map for that mode.
Old 01-30-08, 11:57 AM   #13
The Wankler
FKITALL
Trader Score: (8)
Damn fine looking car!
I got mine yesterday. I am still in the middle of putting a new sun roof in, so it will be a couple days before I get it out. Infact, shit, I just rebuilt the block, hope all goes well when I take it for a drive. it idles like a kitten purres!
Old 01-30-08, 05:32 PM   #14
RotoriousRx7
oh i knew this well before buying it but i wanted to wait and compare my thoughts with others on timing under boost
im going to be going stage 4 bnr pretty soon and plan on pushing 15 psi.
but the afm wont allow that... so all is good for now.
Originally Posted by turbo2ltr View Post
From the website.
Old 01-31-08, 09:17 PM   #15
gxl90rx7
breaking stuff
gxl90rx7's Avatar
i got it installed.. anybody else having problems with the fuel map screen? like settings not taking affect and when you exit and come back all your settings are different?
Old 01-31-08, 10:14 PM   #16
edomund
Bastardized RE AE
edomund's Avatar
I've had it for over a month now, like Mike said and I really like the upgrades.
Just a heads up though, listen to the warning on tuning using the Boost based timing option. If you do not fully understand tuning timing don't use it because the pre-loaded map is !NOT! usable, you can't just tweak it. It is only there because it's the same one used in the stock load based map.
You must create an entirely new map using stock like settings below atmospheric pressure and tuning guidelines or dyno tuning when under boost. The MAP based timing does work very well, you just have to know what you're doing.
I can say that besides my Palm sucking the Rtek 2.1 has worked very well for me so far. I have been boosting 13-14 PSI with much better response (due to the fact that I don't have to use the same timing across the board after the load was maxed at 9PSI any more) and with no detonation.
Ed
88 10th AE & 87 TII (For Sale)
Streetport, BNR Turbo, Greddy FMIC, Ron Davis Radiator, HKS BOV, 720&1000cc Inj. Rtek 2.0, Wideband, RB Turboback, 5zigens, GC Coilover, KYB, ACT Clutch & 14lbs. Flywheel, RE Amemyia FC2000 Bumper/Headlights
edomund is offline   Reply With Quote
Old 01-31-08, 10:23 PM   #17
gxl90rx7
breaking stuff
gxl90rx7's Avatar
what palm are you using? my t3 sucks ass, seems lke it is causing my problems. im switching back to my old m100 tomorrow
Old 01-31-08, 11:45 PM   #18
RotoriousRx7
you detonated ? how bad? and how much boost?
Old 01-31-08, 11:53 PM   #19
95nracer
Actual size
95nracer's Avatar
Ed
What presets are you using for the 720/1000cc injector combo? Do you happen to have a spreadsheet or something we can take a peak at for what you have so far for Boost based timing?
12.1@114
Old 02-01-08, 12:02 AM   #20
95nracer
Actual size
95nracer's Avatar
Grrr... I have the chip, but won't be able to put it in until tomorrow night. I'll probably build a chart on excel or something to work off of.
12.1@114
Old 02-01-08, 01:04 AM   #21
The Wankler
FKITALL
Trader Score: (8)
Yes, I have the palm 3.
Old 02-01-08, 10:09 AM   #22
turbo2ltr
The Tungsten T3 is no longer on our "recommend" list. I spent a ton of time troubleshooting the random disconnects and all I can come up with is that it's an OS bug...which really wouldn't be that hard to believe if you knew how many bugs we had to patch just to get it to connect.
If you have one, I suggest you sell it on ebay and change to something else.
Wankler, are you saying you are seeing the same problems on your Palm III?
Did you guys follow the install instructions in the sticky?
Old 02-01-08, 10:10 AM   #23
turbo2ltr
Just a reminder, if you have a problem, please make a help ticket. http://help.pocketlogger.com
Old 02-01-08, 10:27 AM   #24
Roen
Ex-King of the Loop
Roen's Avatar
How does MAP based timing get around the AFM issue? or is maxing out the AFM still a problem? Thinking in regards to BNR hybrids.
Captain Guardrail / Master Crab Rapist / Crop Dusting Mod
Roen is offline   Reply With Quote
Old 02-01-08, 10:33 AM   #25
boostedfc3s
1.3 liter piston eater
boostedfc3s's Avatar
That's just great, I bought a Tungsten T3 about 3 months ago in anticipation for this 2.1 and now it's no good. WTF
1987 Turbo II. Atkins stage 2 street port w/3mm seals. 60-1 turbo,FMIC,dual pumps,720cc/1680cc,Power FC with Banzai harness. Steve Kan tuned @ 17 psi 352RWHP/296 torque.
boostedfc3s is offline   Reply With Quote
One thing PC users can do that Mac users can't rogrx7 The Lounge 31 03-28-07 10:30 AM
Any Quicken users? dgeesaman The Lounge 4 07-28-06 09:14 PM
To the CT users SIK NE RX-7 Forum 0 09-02-05 01:26 AM
FC nitrous users... Dumbkid-87sb 2nd Generation Specific (1986-1992) 13 04-11-03 08:56 PM
For New users.... ejmack1 3rd Generation Specific (1993-2002) 2 08-22-01 09:15 PM
