Old 01-22-08, 12:09 PM   #1
Fc3s_d1jp
Rtek 1.8 setup
I am rebuilding a 13bt I just bought and swapping it into my gxl. I planned on running a bnr stage 1 turbo but i'm running out of money Will i be running to rich if i have 720 injectors on stock turbo with 3in exhaust. I want to port the engine but i'm kinda scarred of messing it up!
Fc3s_d1jp is offline   Reply With Quote
Old 01-22-08, 07:56 PM   #2
gross polluter
1.8 is made for 720s on both primary and secondary, as long as you run 720's all the way around you will be fine.
88 TII: MS2/E 1.0.2, ZT-2, 1600 secondaries, Supra FP, 3" exhaust, Spearco FMIC - Sold 11/08
68 Mustang fastback: 351C, MS2/E 2.1
90 Laser RS-T: (wrong wheel drive + 400hp)/traction = fail
88 Volvo 245 - Mercedes OM617 powered brick (soon)
gross polluter is offline   Reply With Quote
Old 01-22-08, 11:41 PM   #3
Fc3s_d1jp
I just don't want to be running rich.
Old 01-22-08, 11:57 PM   #4
gross polluter
As long as you run 720s with your 1.8, you wont. Easy as that.
Old 01-23-08, 11:10 AM   #5
Fc3s_d1jp
Great! Thanks for the help.
Old 01-23-08, 02:10 PM   #6
YellowSpeed17
YellowSpeed17's Avatar
Send a message via AIM to YellowSpeed17
I'm still breaking in my engine but at about 1/2 throttle and 5psi my AFRs are between 10-11 whenever I'm in boost. This is with a large streetport, BNR Stage 1, Rtek7 1.8 ECU, and 4 GReddy 720cc injectors. Can't wait for the 2.1 to come out!
Black '87 TII - Large Streetported S4 JDM Engine, Rtek7 1.8 ECU, (4)GReddy 720cc, RP Comp Fuel Pump, BNR Stage 1 Turbo, FMIC, Koyo Rad, BDC TB, RB 3" DP, Apex'i N1 Duals, Ksport Coilovers, GT300 C/F Hood, AIT front and sides, 17" 5Zigen Copse
YellowSpeed17 is offline   Reply With Quote
Old 01-23-08, 02:54 PM   #7
Fc3s_d1jp
Nice!
Old 01-24-08, 11:33 PM   #8
Minnionator
Minnionator's Avatar
really, you should be worried about running lean instead of runinng rich.
running lean= instant death for your new rebuilt. as said, the 1.7 is designed for 550/720 and the 1.8 is designed for 720/720, and nothing else. if you use those exact sizes, it should work fine! if you are going for a 1.8, i would obviouslt suggest a new fuel pump.
Minnionator is offline   Reply With Quote
Old 01-26-08, 01:56 AM   #9
Fc3s_d1jp
Yup, I i'm going to get this kit I saw on ebay, 4 720cc venom inecotors with a 255 fuel
pump.
Old 01-26-08, 09:18 AM   #10
YellowSpeed17
pump.
You might want to do some research on the Venom injectors and fuel pump. I've heard good and bad things about them. My GReddy injectors and Walbro fuel pump seem to do the job just fine though.
Old 01-26-08, 01:39 PM   #11
Minnionator
RC injectors FTW! im quite a fan of them, and they are priced well too!
Old 01-27-08, 12:22 PM   #12
Fc3s_d1jp
humm will do!
Old 02-05-08, 02:38 PM   #13
nu-rx7junkie
nu-rx7junkie's Avatar
You port your motor yet ? I have all the stuuf if you wanna borrow it templates and bits lerge street port and race exhaust templates.
88 SE converted TII, HBP, holset hx52 ,1680cc/720cc injectors, MSII/Extra, old skool hks bov, 50mm hks wastegate ALL built by ME. Brap brap brap.
nu-rx7junkie is offline   Reply With Quote
Old 02-16-08, 01:54 PM   #14
Fc3s_d1jp
Aww man, I already put motor together!! I wish I would have asked you. A large street port would have been nice!!! heres a pic of my motor.
Old 02-17-08, 09:19 PM   #15
nu-rx7junkie
You copied my motor!!!!!!!!!
Old 02-21-08, 06:00 PM   #16
nu-rx7junkie
hey we are going to track again if you wanna go not this friday but next
Old 02-22-08, 06:20 PM   #17
Fc3s_d1jp
Waiting on a couple of parts, But trust me I will hit you up bro!
Old 02-23-08, 09:46 AM   #18
nu-rx7junkie
What parts you waiting on? I have some parts laying around could have what you need?
I am waiting on big alternator upgrade mine is out. And decided against rtek. Going emanage. We will leave friday to the track if you wanna go.Bout 430-530. front champion toyota in south austin.
Hey motor looks good, in fact looks just like mine,? Hey where is mine?
Old 03-09-08, 12:46 AM   #19
fredox19
fredox19's Avatar
Are they 720cc and were can I get them. Also I'm looking into this too, I have a jspec engine that I'm putting in this week on my 88T2. And I want to know if I can run this set up.
720cc, Rtek 1.8, stock turbo, stock IC, 3inch downpipes(not cat) can i use this setup, if so what kind of hp would I get from this set up.
fredox19 is offline   Reply With Quote
Old 03-09-08, 11:08 AM   #20
Minnionator
you can get them in 720CC. you can get them on ebay, or from a registered dealer (speedshops, etc).
Not to sure if you can use the Rtek with the j-spec ECU, but if you find a doner USDM ECU they can modify that for you.
the Rtek comes with a built in FCD, so running the 3" pipe will not cause you to hit fuel cut now.
its hard to say what kind of HP you will make. the bigger injectors and ECU dont make any power at all, it just makes it safer incase you want to produce more power.
I would suggest porting the wastegate on your turbo if you are looking to gain anything more than 20HP haha..
would also suggest getting a stainless or aluminum turbo intake tube (to replace the stock crap plastic one) and a cold air filter to mount to the front of the MAF. might as well make the most of your mod!
Old 03-09-08, 08:54 PM   #21
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
RC eng sells a high-imp 750cc injector, high-imp will work better with the rtek, and eliminate the need for resistors.
the only problem is they dont fit perfectly into the primary positions, you have to grind a little away from teh housing. but no big deal, just take dremel to it
1988 RX-7 TII 10AE BNR Stage 3, Haltech E6k
S5 TII OEM sideskirts replica group buy:
gxl90rx7 is offline   Reply With Quote
A/F Guage setup questions with my rtek 2.0 tIIsleeper 2nd Generation Specific (1986-1992) 6 07-07-07 12:02 AM
Am I gonna blow myself up with this setup? - BNR hybrid setup jdmsuper7 2nd Generation Specific (1986-1992) 17 10-05-06 04:41 PM
Rtek 2.0 setup for modded AE Slo Motorsports Rtek Forum 2 04-25-06 01:50 AM
