Damage Done
Old Jan 16, 2008 | 11:46 AM
Mindphrame's Avatar
Damage Done
At long last I have returned home. Sadly, it's been 2 years, worse its been ~2 years since my baby was started or moved at all. The thought alone pains me. At the very least she has been inside all this time...
This extended absence was far from planned so nothing was done to help her hibernate though this hellish time of neglect.
What I need is helpful suggestions to minimize the damage from this dry start from hell. I plan to drain the fuel/oil and replace of course. What else should I do to minimize the pain? Any tricks? Or do I just pray?
Old Jan 16, 2008 | 11:50 AM
DaleClark's Avatar
RX-7 Bad Ass
Shouldn't need much - change out the gas, change the oil/filter, maybe drain/refill the radiator. Might be worth pulling the plugs and squirting some oil in the spark plug hole, then turning the motor over by hand a few times.
Should be just fine, especially being inside.
Dale
Old Jan 16, 2008 | 12:04 PM
alexdimen's Avatar
TANSTAFL
You could also crank it for several short intervals (egi fuse pulled and battery jumped or on a starter/charger) until oil pressure registers on the gauge.
Did you even disconnect the battery?
Old Jan 16, 2008 | 12:20 PM
mono4lamar's Avatar
In the burnout box...
I would change the oil and filter, check the coolant, put some engine oil in through the spark plug holes, pull the egi and fuel pump relay, and finally crank the engine over till you register oil pressure on the gauge. After all of that replace the fuses and relays and crank her up. Might not hurt to put a charger on it while cranking...
Old Jan 16, 2008 | 03:58 PM
habu2's Avatar
Change the belts & hoses, and all fluids - including brake fluid.
Pull the plugs, squirt some light oil in (e.g. aerosol misting oil), and crank until you have oil pressure. Replace the plugs and fire it up.
Old Jan 17, 2008 | 04:07 PM
Mindphrame's Avatar
Good advise, thanks.
On a side note, I've always been skeptical about fuel additives other then Marvin's oil mix. Would this be a time to run some injector cleaner though?
Old Jan 17, 2008 | 04:25 PM
txturbogs's Avatar
LOL, same advice from all three...kinda like copy paste.
Old Jan 17, 2008 | 06:17 PM
4CN A1R's Avatar
sleeper
Old Jan 17, 2008 | 09:02 PM
MAZDASPEED08's Avatar
dido!
Old Jan 17, 2008 | 09:30 PM
Project88Turbo's Avatar
Stock boost FTW!
One other thing to look out on a car that has set this long is the injectors. Since it has been sitting this long, the fuel can turn to varnish. This could cause the injectors to stick, worst case coming on boost when then secondaries should come online and they deliver NO fuel...
The Turbo II I bought had been sitting for 2 1/2 years and 1 of the injectors was stuck closed. I found this out when I pulled the manifold to replace all the vaccuum and fuel hoses before starting the car for the first time. When I applied power to the injectors individually, one did not click. So, I sent them all off to witchunter.com to be professionally cleaned. It was a good thing too, because the 550cc injectors were spraying 534, 540, 0 (stuck), 528.
Needless to say, I would recommend having them cleaned before driving the car, replacing the fuel filter, and fuel sock on the pump. As sensitive as the FDs can be, it would be worth the extra insurance :-)
As for fuel system cleaner, Seafoam is very good.
Vince
Andrew7dg
Aug 6, 2017 01:41 PM
musker
Oct 1, 2015 05:58 PM
