Factory Motor Mounts. Power?
Old Jan 15, 2008 | 06:59 AM
MR.45's Avatar
How much power are the factory motor mounts good for? Id like to avoid the vibration from after market mounts. I'm building a 450-500 hp street fd that wont be doin much of any launching. will the factory motor mounts hold up or do i need to send my brackets to banzai- racing........
Old Jan 15, 2008 | 08:57 AM
axnjaksn's Avatar
the one and only
LOL!!!! thats what I say I wont be doing much of anything and the first thing I do is exactly what I said I wouldn't. UMMM not to sure about how much power they can handle but do you know how much more vibration there is, looking to buy poly mounts, my factory ones are borderline MIA??
Old Jan 15, 2008 | 09:12 AM
Sgtblue's Avatar
Urban Combat Vet
If you're adding enough mods for THAT much hp, then price shouldn't be a concern. Neither should a little bit more vibration. IMO, you need aftermarket motor mounts. You can add an engine torque brace, but the OEM mounts are still iffy at best.
Old Jan 15, 2008 | 09:19 AM
adam c's Avatar
Cheap Bastard
Solid poly motor mounts are awful. They make the entire car vibrate. If you still have the original mounts on the car, you should at least replace the drivers side mount. It is aluminum, and more prone to failure than the passenger side mount.
Old Jan 15, 2008 | 11:00 AM
MR.45's Avatar
price isnt the concern, especially since the factory mounts are twice as much as most of the after market mounts and i dont have either right now.. If i can get away with using the stock mounts then i would rather use them and enjoy the smooth ride then have to put stiffer mounts and feel like im driving a race car to a car meet. i just want to know if im gonna break the oem mount after a couple hard pulls. id be real pissed to buy oem mounts and them last 2 months.. so my questions remains is it a bad idea to use oem mounts on a 450 hp street fd?
Old Jan 15, 2008 | 11:04 AM
afterburn27's Avatar
Lets Go Hokies!
I would at least run some kind of damped engine brace if you are keeping the stock mounts.
See if you can find a set of the Noltec (sp?) mounts that were being sold on here. I think wanklin was selling them? Most aftermarket poly mounts have a bolt running through the middle that will transmit vibration right into the frame. IIRC, the Noltec mounts were similar to the stock mounts in that there are two studs on each side of the poly material... thus truly isolating the engine vibration from the subframe.
Hopefully that made sense... lol
Old Jan 15, 2008 | 11:39 AM
MR.45's Avatar
Old Jan 15, 2008 | 03:10 PM
Tom93R1's Avatar
gross polluter
The Noltec mounts feel very similar to the stock mounts in terms of stiffness, I imagine vibration through them should also be very similar to stock.
I have a set of the hard poly mounts that are basically a cylinder with a bolt through it and a small puck for under the subframe so the stud never is in direct contact. I honestly dont get much vibration at all through them. I barely feel a difference from stock, maybe without the puck under the subframe you get all the vibrations through the bolt. I imagine that could make a difference.
Old Jan 15, 2008 | 03:51 PM
MR.45's Avatar
what did you use for a puck?
Old Jan 15, 2008 | 05:42 PM
Lets Go Hokies!
You just use a small ring of polyurethane material, same stuff the mount is made of. Kind of like a big thick washer.
Old Jan 15, 2008 | 05:46 PM
bryant's Avatar
bryant
i have some stockers forsale cheap.
Old Jan 15, 2008 | 07:00 PM
MR.45's Avatar
how much?
Old Jan 15, 2008 | 07:17 PM
Noltecs are great. No more vibration then stock, Ihor and I install a pair on every performance build that comes through the door. Also, I've been running the Gotham poly mounts for around 4 years now, no noticeable vibration at all.....of course the 4 inch exhaust might distract me a bit
Old Jan 16, 2008 | 06:56 AM
MR.45's Avatar
thanks for all the help guys. i think im leanin towards the noltecs. just curious how much can i get a pair of those gotham poly mounts?.... thanks!
Old Jan 16, 2008 | 07:17 AM
Sgtblue's Avatar
Urban Combat Vet
.......just curious how much can i get a pair of those gotham poly mounts?.... thanks!
http://www.gothamracing.com/catalog/...160e02e100c86e
I recommend ording by phone though. I've ordered twice from them on line, and neither got processed until about 10 days later when I finally called. I was told some issue with the site.
Old Jan 16, 2008 | 07:24 AM
BlueTII's Avatar
Banzai Racing
http://www.banzai-racing.com/polyfd_motor_mounts.htm
The Noltec require you to have 2 steel mounts.
Old Jan 16, 2008 | 07:45 AM
MR.45's Avatar
where can i get just the driver side solid steel mount?? who sells them?
and "banzai-racing" how would you compare your ploy's to the noltec?
Old Jan 16, 2008 | 08:01 AM
BlueTII's Avatar
Banzai Racing
Completely different designs. After ours break-in there is no vibration, yet the engine and trans movement is decreased drastically. Couple them with our diff brace and you have a firm drivetrain...
Old Jan 16, 2008 | 12:23 PM
alexdimen's Avatar
TANSTAFL
There is also the DIY option using the basic urethane concept, but adding another pad on the other side of the subframe. All of the vibration is absorbed by poly pads instead of only the downward force on normal designs. I did this on my car and never felt the shifter move. No vibration either.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/motor-mounts-521858/
Old Jan 17, 2008 | 07:58 AM
MR.45's Avatar
yep im gonna go with the banzai racing and the ad some poly to the bottom
. thanks everyone
Old Jan 17, 2008 | 12:04 PM
IRPerformance's Avatar
Sponsor
I have extra steel mounts
Old Jan 17, 2008 | 03:03 PM
spandy's Avatar
Patience
There are plenty of steel mounts availiable, just start a WTB thread and you will probably get a few hits quickly.
I bought the Banzai Racing mounts and another steel mount for my setup, just haven't finished it yet and even if I did it wouldn't matter, there is snow everywhere right now.
Old Jan 17, 2008 | 03:37 PM
Lets Go Hokies!
You can actually modify the aluminum mounts to work with the DIY poly material, but I just ended up buying a spare steel mount because they are cheap (~40 shipped).
Old Jan 17, 2008 | 08:06 PM
G's 3rd Gen's Avatar
you can use a passenger steel mount as well. Just flip it over.
Old Jan 17, 2008 | 08:33 PM
MR.45's Avatar
afterburn where did you get your steel mount?
