Koni Yellows: Is this possible?
Old Jan 9, 2008 | 08:54 AM
Monsterbox's Avatar
Mazzei Formula
AL Koni Yellows: Is this possible?
I am installing tein s-techs on my koni yellows and I have no idea how the car is going to sit with the perches on the top level
Is it possible to change the perch level with the strut still installed to the car by compressing the spring in the wheel well?
Does the spring have to be completely removed to change the perch? How do you move the perches up/down?
Old Jan 9, 2008 | 11:58 AM
gracer7-rx7's Avatar
needs more track time
Keep it at the top perch. You'll be fine. Top perch should put you around 25" +- 1/2" ride height.
You need to remove the shock and spring to readjust perches later.
Old Jan 9, 2008 | 03:15 PM
Roen's Avatar
The Silent but Deadly Mod
Can you adjust perches on FC shocks?
Unless of course, you have an FD.
Old Jan 9, 2008 | 07:02 PM
matty's Avatar
on the fd most people do top in front and middle on rear. thats the way my car is but i would probaly go to top on both if i ever was bored enough to make the change.
Old Jan 9, 2008 | 10:46 PM
Monsterbox's Avatar
Mazzei Formula
sorry, forgot the mention yes FD
I want the car to sit completely level. I DO NOT want the back higher like it is in stock configuration
I see the Racing Beat springs drop the front .75 and rear 1.5...this is to compensate for the rear sitting higher
The S-techs however are 1.4 front and 1.3 rear....so there's no compensation
Currently I have stock springs with front struts on middle perch and rear on lowest...it sits ok but not as low as I want I simply want to drop the car evenly all the way around
So with S-Techs you believe that moving the rear back up to the top will still allow the car to drop correctly? Anybody have pictures?
Old Jan 9, 2008 | 10:56 PM
Mahjik's Avatar
Mr. Links
S-Tech's on Tokico's (so that would be front & rear on the same perch level).
Old Jan 9, 2008 | 11:06 PM
Monsterbox's Avatar
Mazzei Formula
wow thats pretty low are you happy with the rear?
You guys think leave it at the top or move rear to middle?
Old Jan 9, 2008 | 11:34 PM
TRISPEEDFD3S's Avatar
FEED me
My car is lower than that. I think I need to raise mine. My rear is actually lower than the front by a tiny bit. I have Koni yellow with H&R springs. Remember everyone's car is different. Regardless if we have the same brand stuff.
Old Jan 9, 2008 | 11:39 PM
Mahjik's Avatar
Mr. Links
It actually sits lower. That shot was taken just after bringing the car off jack stands to wash it. Here's a shot of the front after it settles in:
I would start with the Koni's on the top perch.
Old Jan 10, 2008 | 07:40 AM
matty's Avatar
mahjik....what rims are those? i think u have told me in past but cant remeebr
Old Jan 10, 2008 | 08:57 AM
FEED me
Mahjik, that's more like it...haha I sit like that too...Kinda sucks when the lip scrapes on everything...
Matty I believe those are 5zigen typhoons.
Old Jan 10, 2008 | 11:09 AM
matty's Avatar
any idea on weight?
Old Jan 10, 2008 | 11:41 AM
Mahjik's Avatar
Mr. Links
Originally Posted by matty
any idea on weight?
Yes, they are 5zigen Typhoons. To my knowledge, they aren't made anymore. They aren't "light", I would estimate around 24lbs.
Old Jan 10, 2008 | 03:21 PM
G's 3rd Gen's Avatar
How about koni yellows w/ eibach pro springs? What height settings for an even ride. G
Old Jan 10, 2008 | 04:54 PM
Mahjik's Avatar
Mr. Links
Most people usually start with top-front, middle-rear.
TomU
Jan 3, 2016 09:43 PM
ricardo.benin
Sep 22, 2015 12:06 PM
