Coolant leak at turbo
Old Jan 6, 2008 | 07:23 PM
Wwildman's Avatar
I drive a 88 t2 and after a good cold snap it devloped a coolant leak at a small metal pipe behinde a the turbo . before I pull the turbo off is there any way to repair it ?
Also does this pipe go into the turbo or else where ?
Old Jan 6, 2008 | 11:23 PM
n1ko's Avatar
If its the one I'm thinking of it's the coolant feed line for the turbo, coming from the side of the engine (lower intake manifold I think), down to the passenger side of the turbo's center housing.
It attaches to the turbo with a banjo bolt, so you might just need a new crush washer for that. you don't need to the pull the turbo off to work on this.
Old Jan 7, 2008 | 04:40 AM
Wwildman's Avatar
it is th oppsite one .
Old Jan 10, 2008 | 05:53 PM
trickfc's Avatar
the one on the bottom??
if I remember right, there is the turbo, a gasket, an adapter then a hose that goes back into water pump housing. hose would be my #1 suspect. unless you had like no antifreeze in system and something froze/cracked. I would try to not pull off turbo if at all possible...
Old Jan 12, 2008 | 03:52 AM
Wwildman's Avatar
Well after pressure testing the coolant system. I found it is leaking at the turbo and not the hose at the water pump housing . So sunday I am going to pull the turbo off .
Old Jan 12, 2008 | 02:25 PM
n1ko's Avatar
It still sounds to me like you could maybe repair it without pulling the turbo. I would guess you just need a new gasket.
Old Jan 13, 2008 | 07:48 AM
Wwildman's Avatar
How would get to it with out pulling the turbo off ?
alphawolff
Nov 17, 2015 05:57 PM
Kyo
Aug 14, 2015 02:00 PM
