Wastegate Problem - 50mm Hks
Old Jan 4, 2008 | 10:17 PM
andre sinclair's Avatar
Members,
I`m having an issue with my HKS 50mm wastegate (genuine). Here`s the history
FD HKS Cast iron Manifold with 50mm wastegate...Turbonetics T-66 A/R .70
I have a 10 psi spring in the wastegate and sometimes it would spike to 12/15 psi
I`ve eliminated the Greddy Profec-b and just connect the wastegate straight. (from the turbo compressor to the side of the gate) still creep to 12/15 psi
So I`ve check the diaphragm and done alot of bench test to see if its sticking and its not.
I`ve got tired of trying to figure this out so I bought an ebay replica. I installed and the same **** happends.
I can't figure out the life of me what the hell is the problem.
The dump tube is an S-bend, could this be the reason for the spiking?
Please Advise
Old Jan 4, 2008 | 10:22 PM
kabooski's Avatar
Laying Down Rotary Law
your turbine might be too small and is overpowering the wastegate
the smallest you should use for any 50 trim and above turbo on a rotary is .81
running lean can also cause spikes
Old Jan 4, 2008 | 10:34 PM
I thought this to be. However, on my 1st Gen it has the same size turbo and it doesn`t even spike at all (I`m using a 52mm innovative indy wastegate) dumping in the atmosphere.
Also, wideband says 10.8 on load.
Old Jan 4, 2008 | 10:40 PM
kabooski's Avatar
hmm i had a 50mm hks knockoff with a yellow 20 pound spring
and it held my boost very steady....
what is your exhaust system?
Old Jan 4, 2008 | 11:37 PM
RETed's Avatar
Where is the WG vacuum line sourced from?
-Ted
Old Jan 5, 2008 | 12:27 AM
-Ted
The side on the WG is connected to the compressor side of the turbo and the nipped on the cap is just open.
Is this correct?
Old Jan 5, 2008 | 10:10 AM
dznutzuk's Avatar
Uncontrollable drifter
The HKS cast iron manifold is a poor design and known for boost spike
Old Jan 5, 2008 | 08:41 PM
Marcel Burkett's Avatar
If your manifold design is poor , you will have to get a larger gate to keep the boost under control.
Old Jan 5, 2008 | 08:52 PM
BASTARD's Avatar
what diameter is the dump tube?
have you inspected the wastegate valve stem to make sure it isnt bent?
I have seen 500rwhp cars use the log without spikes
Old Jan 6, 2008 | 01:50 AM
elnr's Avatar
was your boost controller connected to the top of the wastegate?
Old Jan 6, 2008 | 04:31 AM
[QUOTE=BASTARD;7700600]what diameter is the dump tube?
Dump tube is 1.5 inches
Old Jan 6, 2008 | 04:35 AM
yes it was connected...
The compressor vacuum line from the turbo when to the IN of the Greddy profec-b stepper box.
The OUT from the box when to the top of the WG
The side of the WG went to the intake manifold.
But I`ve eliminated it all together and it still spikes.
Old Jan 6, 2008 | 09:36 AM
twokrx7's Avatar
Need more sleep
I had an HKS race wg on a log mani and it never spiked but instead boost would drop off at high rpm. The smaller HKS wg would boost creep on the same mani, turbo was a t66 with 1.0 p-trim.
Old Jan 6, 2008 | 12:18 PM
maybe I need to rin a bigger A/R size
Old May 13, 2008 | 09:17 AM
SIDEWAYZE_FC's Avatar
Rotarded for life
sounds like your turbo is beatin the shitz out of the wastegate to me...
Old May 13, 2008 | 10:34 AM
classicauto's Avatar
Crash Auto?Fix Auto.
in the first post, you list a .70A/R..................if that's on the turbine, then yes - you need a bigger housing.
If thats on the compressor side, then please divulge your turbine's a/r
Old May 13, 2008 | 12:05 PM
dpf22's Avatar
1.5" plus the fact that it has an s-bend doesn't help flow through the wastegate. 50mm is just short of 2" and you should run piping as such from the wastegate. This will likely be the source of your problems.
Old May 13, 2008 | 10:41 PM
Sesshoumaru's Avatar
Tenseiga
got the hks cast with a 50mm hks wg.
running a 62-1 with exhaust at 1.00 divided i think.
Keeps perfect 14.7 all the way through the power band (ebay spring no less).
The 10psi spring was all perfect (original).
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
