Fuel smell...No leaks???
Old Apr 16, 2002 | 06:45 PM
Rotary93's Avatar
Retired RX7 mechanic
What are the symtoms of a faulty pulsation dampener?
Im getting some fuel smell inside the car when I drive. I pop the hood when i stop and everything on the motor is bone dry and dont smell any fuel.
I did tighen up the gas cap. How much pressure is supposed to build up in there? When I open it I hear a long release of pressure.
I gotta fix this...Any ideas?
Old Apr 16, 2002 | 06:47 PM
Import Convert's Avatar
Big pressure release when opening gas cap is normal. Or at least my car does it.
Old Apr 16, 2002 | 06:49 PM
Mahjik's Avatar
Mr. Links
Question
Yep, same here on the pressure release when opening the gas cap.
Do you smell the fuel during certain parts of driving? Under acceleration only? Under boost only? All the time?
Old Apr 16, 2002 | 06:50 PM
RotaryKnight's Avatar
might be injector o-rings...that's what happened to me
Old Apr 16, 2002 | 07:11 PM
Rotary93's Avatar
I smell gas inside but not around the motor.....
Old Apr 16, 2002 | 07:18 PM
RX794's Avatar
NYC's Loudest FD
Make sure the hoses that are under the hood that go to the carbon canister are connected, the o-rings of the injectors aren't leaking, and the fuel pulsation dampner, as well as the fuel lines.
Old Apr 16, 2002 | 07:58 PM
suganuma's Avatar
no
take UIM off and jumper the TEN and F/P terminals on the diagnostic box in the engine bay. it will pressurize the fuel system to base pressure (38-40 psi) and you should be able to see any leaks if you just look around.
FPD is on the primary rail if you are suspecting it as the source of your leak.....
Old Apr 16, 2002 | 08:01 PM
suganuma's Avatar
no
ah, i just read this....
i would still do the check as i wrote above, but also check the things RX794 mentioned.
are you running a midpipe and/or running very rich?
anything recently installed or changed??
JConn2299's Avatar
reliable performance
This happened to me, and it WAS the gas gap. Tightening it won't help....in fact, what happened was, I had overtightened it at one point, and after that it wouldn't seal properly, which allowed fuel vapors to escape. I bought a new cap from the dealer (it wasn't expensive) and that solved the problem.
Old Apr 16, 2002 | 09:18 PM
Cetchup's Avatar
The Cursed FD
I had my Fuel Pulsation Damper replaced 2 days ago. I had the fuel smell at startup and in the cockpit. Everything looked/smelled normal under the hood. Im pretty sure its the damper. The part costs around $120 but labor for it is a little more expensive. Not too bad though.
Old Apr 16, 2002 | 09:34 PM
pflea's Avatar
Do a search under this in my name. I had the same symptoms. Turned out to be the fuel dampner. Once i had everything removed a replaced the dampner and the forward fuel line just in case. It is not hard to do. Good luck.
Old Apr 16, 2002 | 11:15 PM
Mahjik's Avatar
Mr. Links
Lightbulb
It could be a number of things:
* charcol cannister
* purge control system
* injectors
* pulsation damper
* gas cap
and the list goes on...
First thing is to check the obvious places for fuel leaks. If you don't find any leaks, the next thing is to check the evporative system. Start with the charcol cannister, then move onto the purge control system.
Old Apr 17, 2002 | 07:47 AM
Rotary93's Avatar
Ill check it out.
Thanks Guys!!!
Old Apr 17, 2002 | 08:51 AM
Mister7's Avatar
The smell should come from around the alternator/throttle body if it is the FPD (fuel pulsation dampener). I had the same problem as you. Also, the FPD is notorious for causing engine fires. I was so paranoid, I had my car towed to a mechanic. Of course, it cost an arm and a leg to get replaced.
Microtech
30
Apr 23, 2016 06:37 PM
Captain_Panic
Alternative Fuels
Sep 16, 2015 02:06 PM
86glxNA
Aug 22, 2015 08:54 PM
