Sponsored by: CARiD
New Spark Plugs, did I set the trailing and leading right ?
Old Dec 25, 2007 | 02:50 PM
13b_soldier's Avatar
Pop-A-pop!
I bought a set of spark plugs the other day, and just wanted to know something. Okay, like it shows in the diagram. I just wanted to know if I put them in right or not ? I am newb to rotary engines. Help, I don't want something to happen especially with me running tonight. Lol.
The black ones are the leading, and the red ones are the trailing.
Old Dec 25, 2007 | 03:18 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Trailing are the "T" top one
Leading are the "L" Bottom ones
So how you have it is wrong.
Take the Front Top one and install it into the Rear Bottom, then install the Rear bottom one that you just took out into the Front Top.
The Rotor housing are marked "T" "L"
Old Dec 25, 2007 | 03:52 PM
Uncle Hungry's Avatar
Talk to me....
oh man, lol. Hey at least you knew to ask.
Old Dec 25, 2007 | 04:03 PM
Pop-A-pop!
Thanks a lot guys.
Old Dec 25, 2007 | 04:37 PM
Pop-A-pop!
Heh, I replaced them and that bitch idles like a ************. I taught I fucked up my NGK's. But guess, NGK's are the ****. Heh.
Old Dec 25, 2007 | 04:38 PM
Pop-A-pop!
I don't know much about rotarys. Lol.
Old Dec 25, 2007 | 05:59 PM
cewrx7r1's Avatar
Eye In The Sky
Spend the next few days at:
http://www.rotaryengineillustrated.com/index.php
and you will learn some things.
Old Dec 25, 2007 | 07:44 PM
Snailz's Avatar
Just a question on that, running rating 10s on Trailing and Leading cause any problems?
Old Dec 25, 2007 | 08:49 PM
Mahjik's Avatar
Mr. Links
If you have a fairly stock car, then you'll have less than desirable gas mileage and the plugs will foul quick.
Old Dec 25, 2007 | 09:42 PM
Snailz's Avatar
What are the pluses of it? And if i go holding higer RPM, will the sparks not foul up as quick?
Old Dec 25, 2007 | 11:13 PM
Mahjik's Avatar
Mr. Links
Unless you are running some serious boost (i.e. single turbo), its doubtful you'll heat up the plugs enough for them not to foul quickly.
Old Dec 26, 2007 | 01:33 AM
Snailz's Avatar
Oooo ok
so what are the bonuses of it? :P
Old Dec 26, 2007 | 07:31 AM
Mahjik's Avatar
Mr. Links
Oooo ok
Protection against pre-ignition. If you aren't familiar with spark plug heat ranges, I suggest you do a little reading before throwing different heat ranges on your car. That way you can make an educated selection as to what your car should run.
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
Joe428
16
Aug 19, 2015 06:24 PM
