20b Ecu for Fd???
lemme guess....you have a stock FD and you want to to a 20B conversion, and think its a $2000-$3000 conversion...right??
BTW, you will need something along the lines of a MoTec to get the most out the 20B.
you can run a factory 20b ecu if you get ALL of the stock electrics. or you can use a haltech, motec, autronic, microtech, marelli, maybe even the new aem. there is no plug and play ecu/wiring harness for the car.
mike
mike
sorry if this sounds blunt, but if money isn't a problem, ditch your friend, his shop, and any curiousity of what parts you need for the 20b, and head over to http://www.pettitracing.com with $40k
i can't ditch my friend because he is getting me the parts and motor. instead of spending 40k i only spent 15k all i need is the ecu/wiring. thanks for the ecu info but i just order a haltech(e6k) but i also heard that i need a ig5 for it too is that true?
I would take into account who is going to do the tuning. The tuner should be comfortable and familiar with the ECU you have chosen.
Trending Topics
he knows how to do the tuning/installtion its just i have to find what kind of ecu/wiring i want, plus he is pretty busy and i can't bug him every day about my stuff when he has to handle the customers car first. im not saying that he is the perfect guy for the job but when your friend has a autoshop and its right next to your house its pretty convienant. Plus im just asking about the IG5 on what it does.
hmmmm
You spent 15K...is that the total cost including the car? That sounds off.
Now, if you spent 15K the 20b + parts alone, you're probably on the right track.
The 40K you'd spend at Pettit does not include the price of the car. that's what they charge for the swap alone.
$3000 20B
$2000 clutch
$2000 EMS
$1000 rad + cooling
$1500 IC
$2000 Turbo + manifold (unless you're going stock twins?)
$1000 Exhaust
$100 IC piping
$200 materials for mounting
$500 front anti-sway bar
$1000 Recalibrate suspension
$500 Ignition system
$1000 Fuel System
$3000 Rims and Tires
$1000 LSD
$400 Mazdspeed PPF
That's already broken $20k...
This factors ZERO into labor costs...you've got a pretty GOOD friend helping you...
-Ted
$2000 clutch
$2000 EMS
$1000 rad + cooling
$1500 IC
$1000 Exhaust
$100 IC piping
$1000 Fuel System
$1000 LSD
$400 Mazdspeed PPF
-Ted
No it's not.
You're talking about an OS Giken twin-plate for an FD that retails over $2,000, cause this bitch converts the stock FD pull-type to a push-type clutch.
About the only other thing is the Mazdaspeed PPF unit.
Everything else does not have to come from Japan, but if it did, you're talking an extra 20% premium at LEAST.  That makes it a $25,000+ affair.
I call your bluff...I think this whole thread is a bunch of bullshit.  Care to offer proof of this so-called project?
-Ted
-Ted
if you can get that done for 15k then ur friend would be a pretty rich and busy guy right now cuz there will be so many rx7 ready to put a 20b in there. and if i wasnt to sell my cars i would be the first there. correct me if im wrong.
If your mechanic/friend knows how to tune a rotary then he probably has a good feel about which ECU to use (based upon what he is comfortable with and has worked with before). Like I said before...make sense?
Originally posted by RETed
No it's not.
-Ted
No it's not.
-Ted
I am at the early stages of figuring out the best way to convert an FD. How did you mount the engine?
To me the cheapest/easiest way to mount a 20b would be to use pettit's subframe/spindles. Or somehow make a subframe yourself. The pushing the motor back, recessing the firewall, and chopping down the PPF and driveshaft is alot of work, and you still end up with the shifter not in the stock position.
I am with RETed on this one, stuff in japan isn't that cheap at all, and you still have to pay shipping which most of the time makes it cheaper to buy parts out of the u.s.
I say if you guys know what you are doing then you can probably get it done for about 15k-20k with no overhead or labor costs. Not saying it will be perfect, but it'll run. One thing RETed didn't factor in is rebuild and porting of the engine. Not a must but you are investing this kind of money then you want to be safe and try avoid pulling the motor again and spending 5k that you hadn't planned before. And he didn't factor either using the pettit subframe or moving everything back for you either.
Unless you have a mechanic from japan that has done many 3 rotor conversions, knows his ****, and has a "cheap" way of doing things then I think it will be very costly.
I cant believe you Americans are willing to spend $20K+US on a 20B conversion. Thats NZ$50K.
Our Full rebuild of our 20B cost NZ$12K will full polishing, porting and all new seals throughout (oh and that included removal and instalation.
Now, Turbo and manifold NZ$6k, ECU, NZ$2.5K, Clutch NZ$1.5K, I/C NZ$1K, Radiator $1K,
now that's only NZ$24K, now I know there is labour and a few other bits and pieces, but not another NZ$26K worth.
You guys must go over board.
Exhaust, mate it up to what you already have.
Whats wrong with factory LSD?
Why add rims and tyres into the equation??
I guess you guys don't have "Kiwi injinuity" though do you.
My brothers boss (RX-7 Heaven, NZ) is about to put a 20B into his Bat. i will find out what that costs him. It wil be the first in NZ thats road legal that I know of. He already has one with an alloy 406 V8 and 6 speed in it.
$3000 20B
$2000 clutch
$2000 EMS
$1000 rad + cooling
$1500 IC
$1000 Exhaust
$100 IC piping
$1000 Fuel System
$1000 LSD
$400 Mazdspeed PPF
[/B][/QUOTE]
Clutch NZ$1.5K,
I/C NZ$1K,
Radiator $1K,
All the torque is going to spin anything less than 275 wide tires.  You gonna recommend we keep off the gas pedal now?  The stock LSD breaks with anything over 400lb/ft of torque going through it - that makes it a MUST-CHANGE item in my book, if you're going to even "mildly" modify the 20B.  The stock fuel injectors barely support over 300hp, you gonna keep off the boost too?  You're assuming a lot of fabrication that's gonna be FREE - boy, your shop is going to love you for assuming that much - do you OWN the shop or something?
I'd say you're seriously underestimating the cost to build one of these things.  I tell you what - you build me a an FD with a 20B swap into it, running, putting down at least 500hp for $10,600US, and I'll buy it from you + the cost of the car itself.  Here I am busting my *****, trying to do this conversion for under $20,000US, and you can cut that in HALF!  Boy, that's a bargain!
-Ted
Ted - If anything in Australia, we do get cheap turbos. You can pick up a turbo capable of flowing close to 800hp for under $2000AUD. Granted its not roller bearing, but it makes more than enough power for a triple
ok first off all i don't know why some of you guys are acting like dicks when i asked for a simple question, i thank you for the others for answering my question. second the motor isn't even in the car yet so how am i gonna prove, i have know digital camera unless you want to send me some money to go buy one just to show you and when i said this is my friend of course he is gonna hook me up with the best he can do he has a webpage for his store but its not finish and i don't know if i can even post it up because its not my decision. if you guys are hardcore racers and live in so cal or near Orange county you should all know Speed Image from along time ago that is my friend his new shop is name "Jer" you can say he is pretty much the O.G. of import racers. since some one already answered my question this is my last post . thank You
