How much power??
Old Apr 12, 2002 | 07:42 PM
billyrohm's Avatar
Man who sold his 7
How much power??
m2 intake
m2 medium intercooler
HKS super seq bov
non sequential turbos
power fc
1300cc secondaries
dp, mp(resonated), cb (straight through)
profec b
RP fuel pump
How much power with the above mods 14psi, 16psi??
Thanks
Old Apr 12, 2002 | 07:46 PM
Johnny's Avatar
OG
14 psi = 320ish
16 psi = 340ish
all depends on how well the PFC is tuned..you could get more...but I think my numbers are realistic
Old Apr 12, 2002 | 08:12 PM
JoeD's Avatar
please do not run 16 PSI without race gas, and do not run it at that boost level, regardless of what type of gas, for extended peroids of time.
those numbers that Johnny posted are what you should expect, and be glad to have with those mods.
Old Apr 12, 2002 | 10:25 PM
kwikrx7's Avatar
just another blown FD Oh well, it's inevitable that lot's of these guys will just turn up the boost to get that extra 20-30 hp and not be tuned for it. It's extremely hard to have tuning for 16 psi on pump gas let alone more than that on the stock twins. 15 is the limit to be safe and should be kept around 12-14. But at 14 psi with those mods 340 rwhp isn't unreasonable. Atleast you have the fuel mods to handle it.
Old Apr 12, 2002 | 11:09 PM
All I know is that the BOV is what is giving all that HP. Go baby, GO!!!
Old Apr 12, 2002 | 11:14 PM
billyrohm's Avatar
Man who sold his 7
I think that I'll probably be okay, the most that I try and run is 15 but I run really rich, like 02 sensor readings above 1 volt. It's a Ray Locheed map. I try to just run 10psi normally but after 5500rpm boost creep takes over. I think that I need to figure out how to get rid of the boost creep without losing too much power, any ideas? Maybe a restrictor plate in the exhaust?? I'm going to the dyno soon to find out, probably add some race gas or booster.
Thanks for the replies.
Old Apr 12, 2002 | 11:22 PM
Johnny's Avatar
OG
sounds like time to port the wastegate...
but you can try pills in the turbolines
Old Apr 13, 2002 | 03:50 PM
billyrohm's Avatar
Man who sold his 7
What do you mean by pills in the turbo lines?
I'm running non sequential so I'm pretty sure that the only line that I have that does anything now is the wastegate line and that runs to the profec b.
Thanks
Old Apr 13, 2002 | 04:54 PM
Johnny's Avatar
OG
ok then...didn't think about your mod list...when you mentioned boost creep
port that wastegate
Old Apr 13, 2002 | 08:23 PM
billyrohm's Avatar
Man who sold his 7
porting the wastegate requires pulling the turbos right??
Old Apr 13, 2002 | 08:36 PM
Manolis_D's Avatar
Yep!
Old Apr 15, 2002 | 05:45 PM
billyrohm's Avatar
Man who sold his 7
Went to the dyno
Well I went to the dyno and at 10psi she pulled 306rwhp at around 10psi and at around 13.5/14psi she pulled 326 both at 7400 rpm (didnt rev farther, scared). The wide band read 8:1 for most boost and around 8.5:1 7000 on. Way rich, how much power do you think is in there raising the air fuel ratio to 10:1??
This is a Ray Locheed map so any of you with one are probably running rich too.
Time to get a datalogit and go back to the dyno.
Thanks
Billy
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
