how to decifer tire size...
Old Apr 12, 2002 | 01:06 PM
poor college student's Avatar
Red Mist
Ok, i used the search function to look for tire size, determine tire size, and so on, but i couldn't find out how you decifer the tire size code... like people say 255/number/number... what does each number mean?
thanks in advance
~Jeremy
Old Apr 12, 2002 | 04:27 PM
UniqueTII's Avatar
Slow and old
225 - width in mm
55 - aspect ratio = percent of the width that is the height
17 - rim size in inches
Old Apr 15, 2002 | 12:44 PM
Red Mist
what do you mean percent of the width that is the height? call me dumb, but i don't get it.... i get the 225 and the 17 but just a little fuzzy on the aspect ratio....
Old Apr 15, 2002 | 01:03 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
I have 265/60/16 on my truck.
265mm wide, 60series (very tall sidewalls) 16" diameter
For racing my 7 I run 225/45/13
225mm wide, 45 series, (fairly small sidewall) 13" diameter
The best site to get a visual for all of this: http://www.miata.net/garage/tirecalc.html
Old Apr 15, 2002 | 01:25 PM
neo_omega's Avatar
***Moderator***
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Example...185/60R14 85H or 185/60HR14
185mm x .60=111mm x 2=222mm + 355.6mm(14")= 577.6mm or 22.74"
neo_omega's Avatar
***Moderator***
this belongs to tire/wheels section
rx7jocke
72
Jun 17, 2016 03:48 AM
