Goofy fan question...
Old Apr 12, 2002 | 09:45 AM
geikiganger's Avatar
Having never seen another RX-7 up close and personal while running other than my own, I've got an oddball question that I'd look up in my manual if it wasn't 39 miles away and this being convienient.
1st gens normally came with cooling fans, didn't they? Are they supposed to kick out a small tornado? When I open the hood with the car running, I can barely hear the engine over the fan and there's enough wind when I'm standing over it to whip my hair back. Just wondering because I've seen a few posts mention an electric fan conversion...
Thanks!
Old Apr 12, 2002 | 09:55 AM
mperformance's Avatar
I got that tornado myself...LOL!
Old Apr 12, 2002 | 10:14 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Yep, my '83 GSL sounded like a aircraft starting up it's engine, until I replaced the clutch fan with a electric one.
Old Apr 12, 2002 | 10:32 AM
OtakuRX's Avatar
The Rotorheaded Geek
ya, I found it funny when it cleared out my yard and all. Almost makes it seem like its propeller powered.
Old Apr 12, 2002 | 10:36 AM
Yeah, I've gotten that airplane comment a few times
At least it must be pretty good at cooling down the engine. Every time somebody suggests listening for vacuum leaks I'm like "....riiiiiiiight." I always open up the hood and pretend, but I swear I can never hear anything other than the fan
Thanks guys
Old Apr 12, 2002 | 10:38 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Thanks guys
LOL someone suggested that to me too. I just looked at them and say, "You have no idea what my car sounds like." With the eletric fan, the noise level is reduced alot and it still cools the engine.
Old Apr 12, 2002 | 11:10 AM
What did that electric fan run you? Was is a hard install?
Old Apr 12, 2002 | 11:47 AM
jeremy's Avatar
male stripper
don't do the electric fan mod!!!!!!! secretly, mazda created the rx7 with a rotary powered turbo shaft propeller engine. it was based of the idea of the batmobile's turbine, but on the scale of an affordable sports car. in removing this fan you will gain horsepower but lose the pull of the prop in conjunction with the wheels!
Old Apr 12, 2002 | 11:49 AM
Didn't they make some WWII fighter planes with rotaries? It's all coming together now...
Old Apr 12, 2002 | 12:18 PM
inittab's Avatar
I read your email
Mine does the tornado thing when I first start it up then after about 10-15 seconds it slows down and runs normally. Your clutch fan could be hosed.
Old Apr 12, 2002 | 01:59 PM
error402's Avatar
#!/sup_mod/üb3rg33k
Very easy to install. You could just go down to a local advanced auto parts or auto zone and pick up on there.
Make sure you place the fan on the back of the radiator (closest to the engine) not in front. Make sure the fan is a "puller", to pull air through the rad. if it isn't just switch the wire around and it becomes a puller.
Old Apr 12, 2002 | 05:11 PM
This tells you what you need Goto the 6th post, and it tells you a cheap way to get an electric fan Also, it has some other cheap things you can do It...Is...A...Great...Post.
I love selfproclamation
Old Apr 13, 2002 | 07:04 PM
85RX7GS's Avatar
When I start my 85 up, the fan spins normally for the first few seconds and then goes into 'tornado mode' and goes WOOAAAAAAAAAAAAAAAAAAAA and then goes back to normal turning speed. I'm guessing that your clutch is bad.
Old Apr 14, 2002 | 11:09 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
LMAO@jermey, dude you are too much
Old Apr 14, 2002 | 11:10 AM
MIKE-P-28's Avatar
Mine does the same thing, and so does my 88 vert...Starts up, sounds fine a few seconds later, Vrrooooooom and then normal No problem with cooling, so It can stay that way LOL
Old Apr 14, 2002 | 11:32 AM
85rx7blue's Avatar
MIne does the same thing, sounds fine at start up and after a few seconds its tornado time for about 10-15 secs.
Old Apr 15, 2002 | 02:35 PM
Are you refering to my fan clutch (if their is such a thing) or my transmission clutch?
Old Apr 19, 2002 | 01:59 PM
smnc's Avatar
EliteHardcoreCannuckSquad
My '85 base model's cluctch went out completely, so I had to wire the fan directly to the hub. Keeps the thing running rediculously loud. EVERYONE looks when the car comes down the road.
My -SE on the other hand is loud at first, but as the revs increase the fan speed drops.
atticus_jay
Interior / Exterior / Audio
Oct 23, 2015 11:16 AM
rotor_veux
Sep 19, 2015 07:13 PM
