S4 Control Arms in S5?
Old Apr 10, 2002 | 01:30 PM
Mark S's Avatar
Does anyone know if they are compatible? I know the sway bars are different, but my S4 has suspension Tech. bars I'd like to switch over to my S5.
Also, the ball joints on the S4 arms are removable, whereas the S-5 you have to by the whole $400 arm to replace em.
Old Apr 10, 2002 | 03:41 PM
hypntyz7's Avatar
The LCA's will bolt on in place of each other. The mounting point for the sway bars are different. I think it'd be possible to swap the mounts for the 2 sway bars, but the only time I did this swap I just swapped swaybars as well since I had both cars on hand and they were both stock bases.
BTW I have plenty of s4 LCA's lying around you can have for cheap to try.
hypntyz@charter.net
MattGold
Sep 9, 2015 02:20 PM
