Sponsored by: CARiD
no oil pressure
Old Oct 10, 2007 | 04:08 AM
keenangodburn's Avatar
no oil pressure
i just rebiuld my 87 turbo 2 engine and i have no oil pressure. what could cause this?
Old Oct 10, 2007 | 07:53 AM
CMonakar's Avatar
rebreaking things
No oil pressure when it is running or when you are cranking it? I have an electronic oil pressure gauge on my motor. It took several minutes of cranking to build pressure of any kind.
Old Oct 10, 2007 | 08:53 AM
KBSRX7's Avatar
heh
It has to be a gauge problem. I think it is impossible to have NO oil pressure. Unless it has NO oil! HA
Old Oct 10, 2007 | 08:52 PM
i havent started it up yet so, no oil pressure when cranking.
Old Oct 10, 2007 | 09:14 PM
Gohan3rdrift's Avatar
Movie Star
I'm not sure if the TII has that plastic white, and black rubber o-ring in the front cover but are you SURE that's installed?
you sure?
Old Oct 10, 2007 | 09:15 PM
CMonakar's Avatar
rebreaking things
Try removing the spark plugs to increase the cranking speed. Defined Autoworks gave me that tip and it made it easier to build pressure using just the starter motor. Once you have pressure of any kind it will come up very fast when the motor starts.
Old Oct 11, 2007 | 04:06 AM
im just trying to find all of the possibilities and then start trying to find out what went wrong. good idea ill try that.^
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
