Sponsored by: CARiD
Simple racecar wiring
Old Oct 7, 2007 | 06:18 PM
Papasmurf's Avatar
Can anybody show me a simple wiring diagram for my car. It is a 73 rx2 I want to wire it for:
battery
keyed switch
ignitors
distributor
coils
alternator
starter
I want to make a wiring harness because this car has no harness, and I have been reading wiring diagrams for some time and still can't figure it out. I am going to start this thing on the stand before I put it back in the car. The motor is an 87 TII if that matters. I am locking out the distributor. Also, no DLIDFIS, just want to wire it up first.
The thing that screws me up the most is the distributor and the coils and ignitors.
Thanks to anyone that can help. Shawn
Old Oct 7, 2007 | 11:33 PM
Papasmurf's Avatar
The distributor also has the ignitors mounted on it . Thanks guys
Old Oct 8, 2007 | 02:54 PM
Re-Speed.com's Avatar
Large Gauge cable from POS on battery to large lug on starter
Large Gauge cable from NEG on battery to ground - I like to run it to a bolt that holds the starter in.
Large Gauge ground cable from Engine to Chassis.
Ignition voltage to the POS side of coil.
Wire from POS side of coil to the top of the "T" connection on ignitor.
Wire from NEG side of coil to the vertical of the "T" connection on ignitor.
Do the above for each coil and corresponding ignitor. Leading and Trailing.
Wire from the alternator post to the positive side of the battery.
Ignition voltage to the top of the "T" connection on the alternator.
Hope this helps.
-billy
Old Oct 9, 2007 | 12:48 AM
Papasmurf's Avatar
I am sure if I draw it out, it will make sense. I really appreciate your response, thanks. Shawn
Old Oct 9, 2007 | 12:54 AM
Papasmurf's Avatar
There is suppose to be a small wire on the selenoid that goes to the keyed switch, and then to the + or the - side of the battery?
Sorry, but can you tell me which connectors on the ignitor you are talking about.
Make it easy for me and just say left or right. Thanks, sorry for the hassle.
Okay, obviously there is suppose to be a certain plug for the ignitor and I don't have one. Anything else I can do?
Old Oct 9, 2007 | 01:47 AM
Papasmurf's Avatar
So, is C on the ignitor - and is the B + ?
Old Oct 9, 2007 | 04:11 AM
MRJACK$ON's Avatar
Hello research Painless wireing kits(jegs/summit). They come pre-wired & labled,all you need to do is wire power to it & ground each component as needed. Hope this helps.
Old Oct 9, 2007 | 07:42 AM
Yes, there is a male spade terminal on the end of the starter. Give this 12 volts with a push button or a switch only when you want to start the car.
Look at the ignitor plugs. They have two male spade terminals. They form the shape of the letter "T", one horizontal terminal and one vertical. The horizontal terminal is the "top of the T" I mentioned.
If you are standing on the drivers side looking at the distributor the ignitor to the front of the car is the leading, the ignitor to the rear of the car is the trailing.
You do not necessarily need the plug, use female spade terminals.
-billy
Old Oct 10, 2007 | 11:27 PM
Papasmurf's Avatar
Thanks a million man, I will be making this thing shortly....
Lou Byer
20
Oct 12, 2020 08:03 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
JoesFC
Oct 5, 2015 08:10 AM
